Previous in Forum: Six Sigma Verses Process Capability   Next in Forum: Resistance Spot Welder
24 comments
Shuttle Tank
05/21/2016 9:46 AM
live shot a few minutes ago of tank being moved past the first golf course I ever played
Re: Shuttle Tank
05/21/2016 1:43 PM
stuck making a turn...
Re: Shuttle Tank
05/21/2016 4:20 PM
If the pedestrians weren't blocking the path, the driver could have swung out wider.
Re: Shuttle Tank
05/21/2016 1:45 PM
e arrival of the 66,000-pound tank means the California Science Center - located in Exposition Park, across the street from the USC campus - will have the only existing full stack of real Solid Rocket Boosters, Orbiter and External tank on display.
"The donation of this never-used artifact from NASA is significant, and allows the Science Center to fulfill its vision of building a full stack for Space Shuttle Endeavour's final display in the launch position in the future Samuel Oschin Air and Space Center
Re: Shuttle Tank
05/21/2016 2:18 PM
ooppps, a lil to close to the sign
two boom trucks repairing signal after "love tap"
Re: Shuttle Tank
05/21/2016 4:03 PM
Interesting.
Re: Shuttle Tank
05/21/2016 4:25 PM
crossing Crenshaw Blvd in Inglewood, you can see a plane from LAX in the upper left
Re: Shuttle Tank
05/21/2016 4:24 PM
Here's a nice little Fermi problem: Using only the information in the OP, plus general knowledge of vessel construction, estimate the wall thickness of this tank.
Re: Shuttle Tank
05/21/2016 4:26 PM
would 9 feet of concrete be a bit thick?
Re: Shuttle Tank
05/21/2016 4:29 PM
That may be an estimate, but not a very close one! Wrong material, too.
Re: Shuttle Tank
05/21/2016 4:38 PM
its insulated steel? not aluminum?
Re: Shuttle Tank
05/21/2016 5:35 PM
I don't know, and that would give about a 2.5:1 ratio between wall thickness estimates of aluminum versus steel.
Re: Shuttle Tank
05/22/2016 5:36 AM
If steel, sounds reasonable. I don't know the dimensions of the tank, but by comparison with other stuff, I would guess about 20 ft x 80 ft.
Good Answers: 137
Re: Shuttle Tank
05/22/2016 6:02 AM
I worked on 6m x 25m, very close to yours
Re: Shuttle Tank
05/22/2016 6:42 AM
It may be interesting when eventually we look all this up. If we're close so far, that's a pretty thin-wall tank. I don't yet know how dense the contents are, and how much pressure is generated by weight plus acceleration. From another thread, it appears that the tank may made of a copper-enriched aluminum alloy, which by weight could maybe make it 20 mm ~~3/4 inch thick.
Good Answers: 137
Re: Shuttle Tank
05/22/2016 7:06 AM
I thought it's a bit thin, but for 66000 lb it must be something like that if it's steel. About 21mm if it's aluminium.
Re: Shuttle Tank
05/22/2016 7:36 AM
If that thin of steel, I wonder if it would sag of its own weight, but of course it could be pressurized to say 10 psig for shipping.
(I have specifically refrained from other than mental-estimate calculations so far, because this is intended as a Fermi exercise.)
Good Answers: 137
Re: Shuttle Tank
05/22/2016 7:41 AM
I suppose that's Enrico Fermi, but why him? You've lost me there.
Re: Shuttle Tank
05/22/2016 8:06 AM
The classic example is, How many piano tuners are there in Chicago? The idea is that in the absence of information, one tries to make reasonable assumptions and estimates before looking it up in the Yellow Pages. The Drake equation is similar.
Good Answers: 137
Re: Shuttle Tank
05/22/2016 9:37 AM
Still don't see what it has to do with Fermi
Re: Shuttle Tank
05/22/2016 3:47 PM
Because he posed that problem (and perhaps other similar ones) as a thinking exercise in class.
Good Answers: 137
Re: Shuttle Tank
05/23/2016 4:48 AM
OK thanks
Re: Shuttle Tank
05/23/2016 8:27 AM
Don't forget, it's not completely hollow, and it has external components as well...
There was actually three different designs, the early standard weight tank(SWT) the lighter lightweight tank(LWT), and the lighter still, super lightweight tank (SLWT)...
77k, 66k, and 58.5k lbs respectively...153' x 27' overall...
Good Answers: 137
Re: Shuttle Tank
05/22/2016 5:07 AM
I estimate ~ 7mm
Re: Shuttle Tank
05/24/2016 12:49 AM
The SLWT is only 2.5 mm thick Al-Li alloy with .5" of epoxy and ~2" of spray-on foam insulation....
Register to Reply 24 comments
Codemaster (6); Fredski (6); lyn (1); SolarEagle (2); Tornado (9)
