Previous in Forum: Change in Input energy   Next in Forum: Dilution Anomaly in LiBr York Chillers YIA-ES5C3 vs YPC-ST400
Vacuum Gauge Vibration
05/23/2016 4:46 AM
Hi
we are refurbishing an exhauster with vanes and rotor, when am testing it the vacuum gauge does not stand still but it keeps vibrating, which I believe its not write as I want to record the readings, what could be the cause of the vibrating vacuum gauge?
Re: Vaccum
05/23/2016 5:30 AM
It could be any combination of:
  • The design of the gauge
  • The location of the gauge within the process pipework.
  • The vibration caused by the exhauster.
  • The vibration caused by something else.
  • Some other cause.
As the forum cannot see the installation, any further commentary is pure hypothesis.
Re: Vaccum
05/23/2016 6:15 AM
Sounds like air turbulence...I would look for obstructions in the tube leading to the gauge, or placement of the feeding tube angle, or location, or air leak in the connections or tube someplace....when you say the gauge is vibrating, are you saying the needle or the entire gauge? I assumed the needle....
Re: Vaccum
05/23/2016 8:41 AM
yes it is the needle that is vibrating and according to the spec the supply of current to the drive is constant which means the output of vacuum has to be constant too, so the needle has to be stable at all times?
Re: Vaccum
05/23/2016 9:33 AM
Reselect the gauge for a different one with either:
  • a glycerine fluid fill or
  • a snubber.
Re: Vaccum
05/23/2016 12:05 PM
Anyone who has synchronised carburetors will know exactly what you're talking about. Sometimes a needle valve works well as a snubber.
Re: Vaccum
05/24/2016 9:46 AM
We see the same thing happen to the barometer on the flight controller of a quad-copter. The solution is a snubber over the hole. In this case the snubber is a piece of open cell foam rubber. Then the barometer will not see the pulses from the props. The snubber slows the reaction times and so smoothes out the reading to a more ambient/average reading.
Register to Reply 6 comments
Brave Sir Robin (1); Deefburger (1); PWSlack (2); qiniso (1); SolarEagle (1)
