Previous in Forum: Designing of Evaporator   Next in Forum: Vacuum Gauge Vibration
16 comments
Change in Input energy
05/20/2016 4:49 AM
In a vapor absorption cycle system, if there is change in input energy that is energy at generator then will there be any change in energy extracted at evaporator.
Is there any way to control it?
Consider a case : Initially Qg = 600 kW and Qe = 150 kW, now Qg increases to 1000 kW how will Qe change ? If Qe changes , as I want to maintain a constant refrigeration effect is there any way to stop change in Qe?
Re: Change in Input energy
05/20/2016 5:06 AM
Aslo please tell what wil happen if Qg decreases to 200 kW
Good Answers: 109
05/20/2016 6:18 AM
Posted by:
piyusharas
Wanna bet?
05/20/2016 6:29 AM
If you are paid for answering questions here, then I think you should not be. :-D
05/20/2016 1:34 PM
For each answer, we get paid ten times what you pay for asking.
05/20/2016 1:43 PM
I demand to be paid 1000 times that amount!
05/20/2016 1:58 PM
And thus it shall be. Congratulations on your raise.
05/21/2016 2:51 AM
Lol... We don't pay for asking..
05/21/2016 7:01 AM
"Lol... We don't pay for asking.."...and you get what you pay for! lol
05/21/2016 1:47 PM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
05/20/2016 10:22 AM
my initial assumption
Good Answers: 104
05/20/2016 6:54 AM
What do you think will happen?
05/20/2016 7:08 AM
Can you please clear my doubt!
05/20/2016 8:54 AM
What doubt?
05/20/2016 8:55 AM
Why on earth would there be a change in input energy?
05/20/2016 9:05 AM
Something happened.
05/20/2016 9:58 AM
Firstly, you did not state the entire system. The generator is not turning itself, is it? What is turning the generator, gas turbine, ICE, steam turbine? Where is the source of evaporator input energy, boiler stack, HRSG stack, gas turbine exhaust, ICE exhaust?
Generally speaking all of these machines will increase mass flow of exhaust when the load (and hence the fuel burn) increases on the generator. The mass flow of heat to the evaporator follows this, and so must available heat for transfer at the evaporator, up to the limits of heat absorption by the evaporator.
To hold your refrigeration constant with increasing load on the generator, you will have to introduce bypass flow of the evaporator output, such that this bypass will be cooled and condensed without producing any refrigeration effect at the refrigeration load, if that is what you intended to do. When decreasing load on generator appears, there will be a point at which bypass must close, and a further point at which the evaporator is under-driven, and the refrigeration load overcomes refrigeration output.
Reply to Forum Thread 16 comments
Anonymous Poster (4); bigg (1); Brave Sir Robin (2); Fredski (1); IdeaSmith (1); James Stewart (2); piyusharas (1); PWSlack (2); redfred (1); Tom_Consulting (1)
