Previous in Forum: Ex nA Motor in Hazardous Area   Next in Forum: A Little Spark Could Turn Your Sight Sharp
11 comments
Electric Field and Charged Particles
07/08/2016 2:36 AM
if i have two charged particles, then attractive / repulsive force will generate refer to polarity of charges.
what will happen if i grounded one of them. which probability is correct?
1- the force between particles ''if it was attraction'' will prohibit charges from goes to ground.
2- the grounded particle will loose its charge and the force will be between the charged one refer to ground
please read the question well before answering.
Re: electric filed and charged particles
07/08/2016 6:33 AM
'...please read the question well before answering..'
Please formulate the question well, before requesting well considered answers.
07/08/2016 3:26 PM
what is the problem in my question?
Reply Score 1 for Off Topic
07/08/2016 7:01 PM
I'd have to actually know what you intended to ask in order to tell you what the problem was....in which case there wouldn't be so much of a problem.
It isn't enough merely to lack of an obvious problem.
07/08/2016 8:26 AM
News flash: Everything you touch contains charged particles.
07/08/2016 3:46 PM
i understand , but what should happen if you touch an charged particle coupled with anther one with different polarity (distance between them).
the particle will release its charge to you or attraction force will prohibit that.
07/08/2016 8:48 AM
Do your own homework!
07/08/2016 9:04 AM
I doubt this is a homework problem. Homework problems are more cogent.
07/08/2016 11:57 AM
Not after being sifted through the "stupid" filter.
07/08/2016 3:48 PM
if you know . just reply.
Good Answers: 181
07/08/2016 8:08 PM
If you explain the question we may stand half a chance of answering.
Re: Electric Field and Charged Particles
07/08/2016 9:31 AM
what was your instructors response?
Anonymous Poster (3); Fredski (1); Kilowatt0 (2); redfred (2); TonyS (1); truth is not a compromise (2)
