Previous in Forum: Submersible Pump Flow Discharge   Next in Forum: Design
22 comments
Manufacturers Of Mechanical Locking Hydraulic Rams
07/19/2016 6:21 AM
Can the kind people here share the names of any manufacturers who produce hydraulic rams that have a secondary or even a triple layer of redundant safety mechanisms built in ?
We have equipment that requires an extremely high level of safety.
Our current cylinders are double acting with a built in pilot operated check valve to prevent them opening , however we have experienced failures where either the ram piston seals split / became worn and bypassed fluid or the check valves get blocked open by small bits of debris such as hydraulic hoses degrading and shedding tiny bits of rubber inside the system before they passed through the filters , causing the rams to open .
We would like to find cylinders that have a secondary mechanical lock in addition to check valves / counterbalance valves , if there are any with microswitches or movement sensors that would be a plus.
The difficult aspect we face is that the rams dont travel to the same end of stroke position every time , the position where we want to lock them can vary anywhere between 65 % to 100 % of the stroke , and that is where we require them to stay until hydraulic flow disengages the locking mechanism.
Any suggestions for manufacturers / suppliers anywhere in the world ?
Re: Manufacturers Of Mechanical Locking Hydraulic Rams
07/19/2016 1:24 PM
Go here, at the top of the page:
Products & Suppliers
You can find whatever you need there.
07/19/2016 4:22 PM
If blowing out and or chewing up piston seals and having hoses collapse internally sending bits of rubber everywhere that plug up critical interlock components says to me that there is a total lack of proper maintenance given it's critical fail to safe mode requirements.
When was the last time the filters were changed and inspected?
When was the last time fluids were changed and inspected?
When was the last time hoses were replaced?
When was the last time hydraulic cylinders were overhauled?
Anonymous Poster #2
07/19/2016 4:44 PM
Maintenance? MAINTENANCE?
We don't do no stinking maintenance!
07/20/2016 1:08 AM
Yup
I expected those kind of replies.
A very important part of engineering is to understand the question and find answers for it rather than creating your own F.tainment
Reply Score 2 for Off Topic
Anonymous Poster #2
07/20/2016 1:26 AM
And asking an anonymous forum to solve your ill defined symptom is not engineering.
Ask the cylinder supplier to help you. Admit to them that you are not an engineer.
07/20/2016 2:29 AM
I didnt ask you to solve a problem.
I asked for people to post names of suppliers or manufacturers of a product , because 2 hours of googling and emailing companies came up blank .
CR4 ADMIN: Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Reply Off Topic (Score 3)
07/26/2016 4:12 PM
The telephone is the correct tool for the job.
Email? Pah!
Good moaning!
07/20/2016 4:48 AM
what do you actually come here for ?
A question was asked but you didnt answer the question did you ?
07/20/2016 1:23 AM
There is now a person doing all of the above in response to the failures identified.
The same person also wants to find a replacement cylinder that has a secondary safety mechanism to overcome the risk that any of the incidents you have mentioned could occur suddenly.
Even if you replaced the 97 hoses on a yearly rotation ( when 5 yearly when be adequate ) there is still the risk that a tiny bit of hose could be stuck to a fitting since manufacture and shed itself 4 months after the hoses were replaced , hence we want a secondary layer of protection........
So thank you for adding the criticisms and assumptions , however they are already on the table.
So who manufactures cylinders with mechanical locks ?
The list that Lyn very kindly linked to gives me only one so far ( DME )
07/20/2016 3:24 AM
I don't know that anything in your primary system can be completely foolproof. You may need some kind of secondary system that actively clamps the primary actuator.
07/20/2016 4:44 AM
We consider the existing system is inadequate as there is no secondary lock.
As mentioned the primary system has failed twice , once with a check valve that blocked open and once with a split piston seal , both of those scenarios cause a failure in function in a system where zero risk is required.
I am hoping to find a cylinder that has a "deadman type" of shaft lock where loss of hydraulic pressure will lock the cylinder rod in whatever part of its stroke it was in at the moment of failure , on top of having a Counterbalance valve or check valve at the primary level.
07/20/2016 5:25 AM
Knowing what the thing is and what it does would be helpful to us being we are not you and we have no clue what the machine is or what it does or how old or how well or poorly its run and maintained from day to day.
How long has the system been in operation and what is the typical run time between failures?
As for being rude to everybody that asks a question of you that how we work things down to find the best answers to your questions.
Also, there is no such thing as 100% fool proof. Stuff wears out, stuff breaks unexpectedly and unknowns will always happen. The key is to reduce the chances by doing reasonable preventive maintenance but to always accept that the next inevitable breakdown will happen. 0% failure is an impossible number that only fools and management who don't have a clue about how reality actually works aim for.
0% failure is an impossible number that only fools and management who don't have a clue about how reality actually works aim for. Same with expecting answers without giving any relevant info about the what's what of your problems.
Without knowing anything about your system here is what I found on a simple Google search for "Self Locking Hydraulic cylinders"
Self locking hydraulic cylinders
I'm guessing you already found them and they won't work for you being if you had already done a search yourself for a 'self locking hydraulic cylinder' you wouldn't be here asking anything.
(This whole thread is just one more reason I hate the AP function here and I already regret participating.)
07/20/2016 8:54 AM
I agree,nothing can be 100% failure proof...Even NASA with 5 redundant systems has failures.
All you can do is reduce the probability to an acceptable level using redundant backup systems,separate and independent of the primary system.
07/20/2016 11:46 AM
I agree completely about AP's.
Especially AP's with attitudes!
07/20/2016 11:18 PM
thanks for the serious consideration that you have given in your reply.
people sometimes dont disclose all the information about an application due to commercial or contractual sensitivity , however i can say it is ground based but associated with avionics and marine.
It has been in operation for nearly 40 years , albeit with complete rebuilds and also spot maintenance over that time as required , it is not run daily but has prestart tests and routine diagnostic tests before being operated under load , the 2 failures occurred during operation some hours after prestarts were carried out.
You might argue that 2 documented failures in 40 years in negligible however the current operator of the equipment has a strict safety philosophy and has tagged off the equipment until an appropriate upgrade is implemented.
Modern equipment in this role will have no less than 2 levels of redundancy with electronic indicators and automatic isolators to cut operation in fault mode , and that is why i am looking for products to fullfil that need.
Yes , i have searched self locking , shaft locking , auto locking , mechanical locking cylinders but nothing suitable was found yet.
optimism is still maintained .
thanks for your reply
07/20/2016 3:31 AM
Depending on how much force you need, some other type of actuator such a ball screw might be easier to lock in a fixed position.
07/20/2016 8:47 AM
It is impossible to make anything foolproof...because fools are very ingenious.
07/20/2016 9:54 AM
Stepper motor.
07/20/2016 11:36 PM
high torque low speed linear stepper motors have been looked at but they would require a massive modification to incorporate a slip ring into a rotating assembly.
We would prefer a drop in hydraulic cylinder replacement if we can find one but the steppers are still on the table for consideration.
thanks for the thoughts.
Good Answers: 153
07/20/2016 10:12 AM
AMLOK™ series RCH rod lock clamps, Comes with an intergal proximity switch port. Manufacturer Advanced Machine & Engineering Co. There are lots of alternatives based on the same operating method. No recommendation implied, just the first one I came across.
07/20/2016 10:48 PM
:) thankyou
07/20/2016 11:28 PM
that is the closest product range so far to achieving what we want , a little bit more compact in length would be good but we have contacted them.
( and they didnt come up in the searches i did btw )
thankyou kindly
Reply to Forum Thread 22 comments
Anonymous Poster (11); Crabtree (1); HiTekRedNek (2); jhhassociates (1); lyn (3); tcmtech (2); Tornado (2)
