Previous in Forum: Manufacturers Of Mechanical Locking Hydraulic Rams   Next in Forum: BFP Discharge from BFP Intermittent Stage
20 comments
Design
07/21/2016 11:48 AM
I have an i-beam placed horizontally and i want to apply 1 ton point load on its center. Now i will run a stress analysis on ansys on it and will get the displacement in the beam on the mentioned load. How will i know tht the displacement value i am getting is good or bad?
Re: Design
07/21/2016 12:10 PM
You won't know until you test it with a real I-beam and one ton of force. Welcome to engineering.
Sorry for being flippant, but any stress analysis is only as good as the data you feed it. If you have very good material data on the I-beam you plan to use, the stress analysis results can be very good.
Re: Design
07/21/2016 12:16 PM
Good or bad, compared to what?
That's why engineering has standards and specifications.
Re: Design
07/21/2016 12:25 PM
If i find deflection analytically and thru ansys and both values validate eachother. But tht wud not be the measure tht specific amount of deflection is good for the beam or not ?
Re: Design
07/21/2016 12:30 PM
I believe the question you want answered is how much deflection is considered acceptable for a given I-beam. I would start here:
https://www.google.com/?gws_rd=ssl#q=acceptable+deflection+of+a+steel+beam
or here:
http://cr4.globalspec.com/thread/100373
Re: Design
07/21/2016 1:38 PM
Interesting about the last reference.... I complete that project up last February. I was told to focus at the project at hand and NOT to look at the stresses and they did not want me doing the again.
Here's an update when the project got started.
Crane$ 2,500.00Portal to portal costs
Crane$ 450.00hourly cost
Refractory crew$ 1,560.00hour (12 men @ $130.00/hour each)
Inhouse Crew$ 140.00hour (4 men @ $35.00/hour each)
** Total$ 2,150.00hour
** not including the $2500.00 portal to portal cost for crane
When we were well on our way of rebuilding, one of the managers were concerned that some of the maintenance people were complaining that the structure would not hold up. I had something to do with that, because I told the maintenance and showed the issues. (Just due to safety)
So my manager came up to me and said that to me that there's concern about the integrity of the structure.
Well, my response to him was..., I first used his words against him and watched him sweat. What he didn't know was, I already initiated plan 'B' of reinforcing the structure and that was already half complete. And I told him, the structure will now hold up to the stresses. I tend and rather do things correctly and ask for forgiveness later.
What pissed me off, he then said "It was my call".... wtf.... now its my call when I have $2150.00/hour, scheduled down-time but it wasn't my call a year ago when I brought the issue up and was told not to worry about it.
By the way, when I was told not to worry about it, that was being kind... I was actually reprimanded.
Re: Design
07/21/2016 6:49 PM
With that kind of 'support' I think I would be looking to contribute somewhere else. But then again, there can be many other variables that plays into that sort of decision. Paper trails can be very important in these situations.
Re: Design
07/21/2016 8:15 PM
I am... Or was.... One thing happen, I received a letter from the owners (three of them) of the company and out of the blue, gave me a 5 figured bonus... (Nice to be appreciated)
You were right.... What was at issue, they (management) didn't want to risk having to recertification the oxidizer (EPA, DNR, ....) because it was grandfathered in. Hell, I easily could have and did worked it in a maintenance program. But to risk safety by the managers for the sake of paper work, that irked me.
I'm still open because I don't want to keep fighting 'the internal system'.
Re: Design
07/21/2016 1:22 PM
Re: Design
07/21/2016 5:54 PM
Billiard hall: L/1000 ??
Good Answers: 266
Re: Design
07/21/2016 1:34 PM
Re: Design
07/21/2016 2:01 PM
Thankyou guys....it seems in civil there are codes for the allowable deflection.
Good Answers: 70
Re: Design
07/21/2016 5:18 PM
You might consider loosing your texting shorthand, it will make you sound more credible if you use complet words
Re: Design
07/21/2016 5:50 PM
Give a letter here, take a letter there. (Extra o in loosing, missing e in complet.)
Re: Design
07/21/2016 6:52 PM
I think that wuz tong in chek.
Re: Design
07/21/2016 8:41 PM
Give him a break. He just has loose vowels.
Good Answers: 137
Re: Design
07/22/2016 4:58 AM
That's right, but I would calculate deflection manually as a check on ansys (whatever that is, I haven't heard of it, but I haven't been into these things for years).
it's about as simple a beam calc as you could wish for, good practice and e.g. to make sure you've entered the data correctly into ansys. Also you need to decide whether the beam ends are fixed or supported, you didn't say.
Re: Design
07/22/2016 5:03 AM
Both ends are fixed
Re: Design
07/23/2016 12:27 AM
I like the assumption that both ends are unsupported; then the beam is in free fall and the deflection is zero, until it hits something.
Good Answers: 137
Re: Design
07/24/2016 4:36 AM
I trust that's a joke, but I only gave 2 options, fixed or (simply) supported. Where does unsupported come from? ��
Re: Design
07/21/2016 3:04 PM
Just use a two ton I-beam.
Register to Reply 20 comments
Brave Sir Robin (4); Codemaster (2); dj95401 (1); lyn (2); ozzb (1); phoenix911 (2); Shahid sadiq (3); SolarEagle (1); Tornado (3); Usbport (1)
