Previous in Forum: Drive System for a Ship Elevator/Lift   Next in Forum: Spray Nozzle Technology
About the Nomenclature of Refrigerant
08/18/2016 6:41 AM
What does the 'a' in 'r-134a' refrigerant mean?
Re: About the Nomenclature of Refrigerant
08/18/2016 8:05 AM
The numbers indicate the number of atoms in the molecule as described below. The 'a' in r134a indicates that it is an isomer of r134. (Isomers are compounds that have the same formula but the atoms are arranged differently.)
"Numbering system[edit]
Main article: refrigerant § Refrigerants by class
A numbering system is used for fluorinated alkanes, prefixed with Freon-, R-, CFC-, and HCFC-. The rightmost value indicates the number of fluorine atoms, the next value to the left is the number of hydrogen atoms plus 1, and the next value to the left is the number of carbon atoms less one (zeroes are not stated). Remaining atoms are chlorine. Thus, Freon-12 indicates a methane derivative (only two numbers) containing two fluorine atoms (the second 2) and no hydrogen (1-1=0). It is therefore CCl2F2.
Another, easier equation that can be applied to get the correct molecular formula of the CFC/R/Freon class compounds is this to take the numbering and add 90 to it. The resulting value will give the number of carbons as the first numeral, the second numeral gives the number of hydrogen atoms, and the third numeral gives the number of fluorine atoms. The rest of the unaccounted carbon bonds are occupied by chlorine atoms. The value of this equation is always a three figure number. An easy example is that of CFC-12, which gives: 90+12=102 -> 1 carbon, 0 hydrogens, 2 fluorine atoms, and hence 2 chlorine atoms resulting in CCl2F2. The main advantage of this method of deducing the molecular composition in comparison with the method described in the paragraph above is that it gives the number of carbon atoms of the molecule.
Freons containing bromine are signified by four numbers. Isomers, which are common for ethane and propane derivatives, are indicated by letters following the numbers."
https://en.wikipedia.org/wiki/Chlorofluorocarbon
08/19/2016 11:58 AM
It darned sure isn't "b". It is a slight modification from the original molecule, but basically the same chemical formula as to elements present in the compound. Does that help?
It also means that if you look into it (google, etc.) that you will find slightly different regulations exist concerning applications, etc.
Register to Reply 2 comments
