Previous in Forum: 11KV Gensets Neutral Connection   Next in Forum: Determining a Motor Frame Size & Phase
Motor Starting Calculations
08/18/2016 1:37 PM
I want to calculate starting motor electrical and mechanical quantities (Te, V, I, P, & Q) when using a reduced voltage autotransformer starting? Do you have some references or hand calculations for these?
Re: Motor Starting Calculations
08/19/2016 4:34 PM
This one looks to be a practical method, using motor typical published data, to find across the line information.
http://image.sciencenet.cn/olddata/kexue.com.cn/bbs/upload/15714Calculating%20Motor%20Start%20Time.pdf
From this, you can develop the case with your autotransformer lowering the motor voltage at start time, and reducing the voltage dip/flicker on the serving power source. (The only reason I would consider applying a reduced voltage starter on a motor).
08/20/2016 3:03 PM
Not me. Google does, though. Try there.
Good moaning!
Register to Reply 2 comments
