Previous in Forum: Shaft Diameter Of Motor   Next in Forum: Whats Better Australian Muscle or American
API 6A Chokes - PR1/PR2 Testings
08/22/2016 9:40 AM
Hi all, Greetings!!!
For API 6A Chokes, i have some below queries reg testings of validations.
1. i have design the chokes as per API 6A clause 4 with fulfill the requirements of clause 10.9. regarding this, should i do the PR1/PR2 Test as per Table 86 which is reflected in the clause 10.9.?
2.What is the difference between the Table 86(Performance Test Requirement) as per clause 10.9 in API Spec 6A and Annex F PR1/PR2 Requirements? since it is design validation test.
3. If table 86 need to be done means, do we need to perform this test as per Annex F?
4. Is Table 86 PR1/PR2 test mandatory for all chokes?
Re: API 6A Chokes - PR1/PR2 Testings
08/22/2016 11:30 AM
08/23/2016 3:05 AM
A1) Only if the design is following API 6A.
A2) The answer is in API 6A.
A3) Only if the test procedure is following API 6A.
A4) Only if the test procedure is following API 6A.
08/23/2016 3:25 AM
Sorry, i forgot to mention here that the PR1/PR2 testings as per table 86 is mandatory or not?
08/23/2016 3:41 AM
A1) Only if the test procedure is following API 6A.
Register to Reply 4 comments
dineshd (1); lyn (1); PWSlack (2)
