Previous in Forum: Diesel Truck Issues Caused by Dyed Diesel Fuel?   Next in Forum: Cleanroom Design
18 comments
Steel/epoxy adhesion
08/07/2007 3:30 AM
Hello,
I am doing filament winding of glass-fiber epoxy on a carbon steel mandrel.
After curing, it is important that the bond between epoxy and carbon steel is as good as possible.
My problem is that I am sandblasting the carbon steel 24-48 hrs before the epoxy application, which means that some oxidation may develop on the mandrel before I apply the composite. Since iron oxides are not very adherent, this will cost me in terms of bond strength.
Any ideas as to how to protect the surface or a method to restore the pristine surface?
Thank you
Chris
United Kingdom - Member - Member
Re: Steel/epoxy adhesion
08/07/2007 6:02 AM
Obviously oxidisation occurs when the steel comes into contact with oxygen, so storing the mandrels in some kind of helium chamber would prevent it (Helium being an inert gas). Failing this there are a number of things which accelerate oxidisation, namely
Heat
Water
Salt
Storing the mandrels in a cool, dry, ventilated (maybe dehumidified) area will substantially reduce any oxidisation.
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Good Answers: 40
08/10/2007 2:43 PM
"Pardons"... but, simply in the context of "Let us NOT lead others astray"...
In corrosion terminology, "oxidation" is the giving-up of an electron. "Reduction" is the picking-up or gaining of an electron (thus "REDOX" reactions, reduction and oxidation are involved in corrosion of metals).
Except for the fact that oxygen is frequently involved in corrosion reactions (at the CATHODE, as the reduction of oxygen is one of the more common cathodic reactions) corrosion does NOT "Depend-Upon" the presence of O2. Corrosion can, and does happen quite often in total absence of oxygen. Just because both words begin with 'ox" means nothing. "Oxidation", in corrosion techno-speak (and with the exception of the above statement) has nothing to do with "oxygen".
That having been said, for clarification ~~~ "True" to each of the posts here ascribing to the concept that 'atmospheric corrosion' of the mandrel(s) will be eliminated by storing in some manner which excludes both humidity and O2 from the component. Lots of ways to achieve that end.
08/07/2007 6:51 AM
Electroplating or cathodic protection over night? Acid wash? If it's a short time maybe paint the mandrel with unactivated resin. When you subsequently apply activated resin I bet the curing reaction will spread right through? I suppose this might require excluding oxygen while it's waiting.
Wish I was here more often.
Good Answers: 247
08/08/2007 12:54 AM
For this reason, I wet sand pieces like this using mixed epoxy as the "water". Personally, I would not use unmixed resin, because the cure is not certain to spread , and you could significantly change the properties of the epoxy due to the hardener-lean area. (A hardener is not simply a catalyst, and small differences in ratio affect properties in significant ways.)
08/08/2007 5:06 AM
I bow to those with proper knowledge/experience.
Good Answers: 50
08/08/2007 3:55 AM
What about standing the sandblasted parts in a bucket of alcohol or a volatile liquid, like carbon tet? Something that will keep air and water away, but will evaporate quickly when the part is removed.
Of course, I'm suggesting you do this in a responsible manner.
08/08/2007 11:46 AM
Come on Vermin you realy do not want to use that nasty old carbon tet, definatly on the dangerous chemicals list.
I reckon the best procedure is to coat the items with unactivated resin then when ready to use them give them a stiff brushing of activated resin from my experience with epoxies this will give a 100% cure so long as there are no deep pockets on the mandrels.
Good Answers: 50
08/09/2007 12:29 AM
There was a time when we basically swam in carbon tet, tri chloral ethane, and MEK. And we like it! We loved it!
...Actually we worried our asses off, but that was what the company wanted.
Good Answers: 243
08/08/2007 9:43 AM
You ask about protecting the surface so I will answer that first:
Vapor phase inhibitor:
http://www.cortecvci.com/Publications/Papers/VCIProducts/CTP-10.pdf
Vapor Corrosion Inhibitor:
http://www.vapor-tek.co.uk/html/vaporol.htm
Zerust:
http://www.zerust.com/
I have a couple of these capsules in my lockers and travel cases holding my shootin' irons.
They work best in enclosed packaging. Some of these sites sell a paper that is treated with these inhibitors. Wrap your parts and they should be fine when you unwrap them. Perhaps you could just wrap the parts with an ordinary capsule of dessicant like silica gel ( http://www.gracedavison.com/products/adsrbnts/descpkg/overview.htm ) if you are worried about the VPI/VCI interfering with your epoxy.
Real Question unasked but implied in yours: why are you batch processing mandrels 48 hours early? 48 hours of waiting is a lot of waste. Failure to use Just in time will cost you whatever the cost of the materials, labor and additional processing steps of this remediation is...
milo
08/08/2007 1:24 PM
Spray or dip in WD-40 or the like and then just before epoxying wipe them with acetone.
08/08/2007 6:27 PM
...or Methylated Spirits.
Good Answers: 50
08/09/2007 12:33 AM
What the heck are Methylated Spirits?! Are we talking menthol cigarettes here?!
08/09/2007 1:09 AM
08/09/2007 4:34 AM
Perfect explanation, many thanks for the link.
08/09/2007 4:31 AM
Methyl Alcohol for the non UK speakers, sorry......forgot myself!!
It turns you blind if you drink it!!!
Now where is my white stick and the Blind Dog?
08/09/2007 7:18 AM
You're not going to be much use to a blind dog if you have a white stick yourself. If I were you I should take the blind dog back and swap it for a guide dog.
Al
Reply Off Topic (Score 6)
08/10/2007 12:27 PM
.......thats why we both need the stick, but his paws do not allow him to hold it correctly, so he needs me for that!! Wasn't it obvious?
Have a good one!!
Good Answers: 40
08/10/2007 2:24 PM
Several good, logical replies here...(e.g, Milo). Options certainly exist, but of course the values of one over another hinge on a couple critical parameters not yet mentioned. The question, in "NACE" terminology is: "How do you hold the blast?"
What SIZE (LxD) mandrel are we discussing...? 3 inches... 3 feet...? (And, solid or hollow?) Just one ... or, is it an occasionally repeated effort? (Worthy of constructing a dehumidified storage box?)
Two other questions come to mind: 1) If the bond is 'oh-so-critical', have you collaborated with (inquired-of) the epoxy mfr to determine the optimal surface (blast) profile in mils? And, are you using the optimal blast media? ... Pre-cleaning the surface BEFORE blasting, so as not to drive any existing contaminants INTO the profile...? Testing the surface for presence of (invisible) contaminants / FE++ ions prior to the winding... etc, etc? and:
2) Curiosity compels the question; what is function of the mandrel? Is the filament winding truly necessary / justified...? Is there any possibility that there exists a more appropriate "finish" ... which might render your current conundrum meaningless?
Regardless... Best of luck with the endeavor.
Reply to Forum Thread 18 comments
Andy Germany (4); Blink (1); Bolton_Alan (3); garth (1); Milo (1); ndt-tom (2); sail4evr (1); vermin (3); Wrenched (2)
