Previous in Forum: Lubricating Oil   Next in Forum: Economiser Water in De-aerator
12 comments
Thickness Requirement ASME VIII Div.1
08/26/2016 4:01 AM
Dear All,
Can any one tell me where value 0.6 in the formula UG 27 comes from ??, I have tried to work out but unsuccess, I only now that SE must be greater than 0.6 P.
Thanks a lot,
Best regards,
Anonymous Poster #2
Re: Thickness Requirement ASME VIII Div.1
08/26/2016 6:57 AM
It comes from an anonymous source.
Anonymous Poster #3
08/26/2016 1:47 PM
Actually this was proven in a textbook titled:
"Anonymous Engineering", by A.P. Eng III
A.P. is a member of Engineers Anonymous.
The initial factor chosen was 0.5, but it omitted part of the fudge coefficient of gravity, so it was bumped up to 0.6.
08/26/2016 3:28 PM
Was it a 12-step proof?
08/29/2016 10:21 AM
One can easily assume that is was indeed a 12-step proof, Proof # 180.
08/29/2016 7:55 PM
Hi James,
Would you please to share what does it a 12-step proof, Proof # 180 mean ???.
Thanks and regards,
Gus Narwan
08/30/2016 9:37 AM
I was spoofing the AP #1 fellow. 12-step refers to Alcoholics Anonymous (or in this case, Engineers Anonymous) and proof 180 refers to 180 proof alcohol (the highest alcohol content possible without breaking the azeotrope). 180 proof is basically 90%. Proof = 2 x alcohol content in percent.
Moonshine (white lightening) is 180 proof, sometimes less, but never more.
08/31/2016 8:13 PM
Dearest James,
Thanks a lot indeed, It may not familiar to me, but thanks any way
Have a safe life and enjoy.
Best regards,
08/28/2016 8:50 PM
Thank you,
May I have just the part of the proven . . . .
Thanks and regards,
08/30/2016 7:23 PM
Dearest James,
Much appreciated for your valuable information, I will find out Anonymous Engineering", by A.P. Eng III for my reference, if you do not mind would you please to guide me to the right direction to get it.
Thanks and best regards,
Gus Narwan
08/31/2016 9:25 AM
one needs sour mash, and a still to pass that course, and then after about the 4th glass, the standard will appear before your eyes, in duplicate.
08/27/2016 4:02 PM
haha, I believe that is the stated joint efficiency....and it comes from the material used the construction parameters required by applicable code for the intended use of this tank...
http://www.pdhonline.com/courses/m398/m398content.pdf
08/28/2016 9:02 PM
Thanks a lot, good reference,
Best regards,
Anonymous Poster (2); Gus Narwan (5); James Stewart (3); SolarEagle (1); Tornado (1)
