Previous in Forum: Thermal Power Plant Distributed Control System   Next in Forum: Automatic screen opening by remote
Circuit
08/08/2007 10:41 AM
Hi, I would like the circuit for the following
input=0-40v sin wave(4Hz-15Hz)
output=0-40v squere wave(4Hz-15Hz)
Please help me
Re: circuit
08/08/2007 10:46 AM
Is this for power or as a signal..
If it is just as a signal...Amplify it and then chop off the top and bottom of the waveform with zenners (crude dirty way) Or slap it into an op amp with some positive feed back, again you will have to limit the excursion of the wave form.
If it's for power....why?
Good Answers: 18
Re: Circuit
08/09/2007 11:13 AM
Like Del asked, "Is it for power?"
If it's a low-level signal, use an optocoupler with current limiting on input circuit (40 V / 20 mA = 2000 Ohms), which won't give you exactly a square wave, but the transistor output will either be "off " or "on." If you need a square wave, the full-wave rectify the input sine wave and alternate between "on" and "off " with a flip-flop.
'Course, all bets are off if it's for power -- that's a different animal.
Re: Circuit
08/09/2007 8:28 PM
A Fourier Transformer will fill the bill.
Re: Circuit
08/10/2007 3:41 AM
I use a furrier transformer, it's funnier and furrier than a Fourier !
Good Answers: 32
Re: Circuit
08/12/2007 9:37 AM
Humm. Good ideas worth patenting.
Re: Circuit
08/20/2007 4:43 PM
If you Wiki Furrier transformer (just for the hell of it) It comes up with Tom and Jerry
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Re: Circuit
08/10/2007 5:14 AM
you can use a simple comparetoor, such as lm324, lm 339 etc. one input set at 20DC, another inport termianl your signal, the output will be square wave.
Register to Reply 7 comments
Bill (1); cnpower (1); coconutpete (1); Shyam (1); Stirling Stan (1); user-deleted-1105 (2)
