Previous in Forum: What are the Problems and Failures That Would Be Hidden in Traditional Relays?   Next in Forum: Induction Motor Taking Full Load Current at No Load in Delta Connection
Negative Sequence Relay Working
11/04/2016 2:57 AM
Hello,
Since the symmetrical components does not exist in reality meaning they are just mathematical tool to analyse the unbalanced system, then How does the electro mechanical negative sequence relay & digital relays detect the negative sequence currents?
Re: Negative Sequence Relay Working
11/04/2016 12:07 PM
Try reading this. And try google sometime - first.
Good Answers: 181
11/04/2016 2:42 PM
Strange how this thread follows on from:
http://cr4.globalspec.com/thread/109447/What-are-the-Problems-and-Failures-That-Would-Be-Hidden-in-Traditional-Relays
Good Answers: 116
11/06/2016 12:53 PM
This is figure 3.51(d) from "Protective Relays Their Theory and Practice" by A.R. Van C. Warrington Vol.2 published by Chapman & Hall.
What it does is phase lag the B-C voltage until it is 180 degrees out of phase with the A-B voltage. Transformer T (or with electronic amplifier, in place of T, a resistive divider) provides an equal voltage to the capacitor voltage, giving a resultant voltage V2 of zero for positive sequence voltages. However, for negative sequence voltage, this balance is not got and only the negative sequence voltage is present in V2.
There are other forms of negative [and positive] sequence filters.
The symmetrical components can exist in reality - you can set up a system of 2 x balanced, 120 degree spaced, 3 phase and 1 x single phase generators to give any 3 (voltage and phase un-balanced) vectors of a 3 phase supply required.
67model
67model (1); Kilowatt0 (1); TonyS (1)
