Previous in Forum: How to effectively use modern technology to reduce the effort of counting lights   Next in Forum: Negative Sequence Relay Working
15 comments
What are the Problems and Failures That Would Be Hidden in Traditional Relays?
11/04/2016 2:12 AM
I need some information regarding to the hidden failures in protecting substations. Particularly, summarize the following topics: - Causes of hidden failures (indicate references) - Examples of hidden failures (indicate references) - Conventional count measures (indicate references
Good Answers: 181
Re: what are the problems and failures that would be hidden in a traditional relays?
11/04/2016 2:46 AM
CR4 is not a homework cheat site.
11/04/2016 2:53 AM
If you don,t know anything,better keep silent.
Register to Reply Off Topic (Score 9)
11/04/2016 6:48 AM
"If you don,t know anything [about traditional relays] ,better keep silent."start studying them!!!
Do some research, independently!
The person you insulted has forgotten far more about relays that you will ever know.
11/04/2016 2:48 AM
Various unspecified gremlins.
11/04/2016 2:55 AM
Can you elaborate more?
11/04/2016 10:51 AM
These:
This is what happens when you feed your relays bad moths after midnight.
11/04/2016 7:59 AM
11/04/2016 8:18 AM
I'd relay the message, but my list of contacts has currently eroded.
I hope doesn't put a bad crimp in your progress.
reference? Wire you short a few strands?
11/04/2016 1:21 PM
Nicely done and very informative. I do fear however that the self-imposed knowledge blocks will render such gems superfluous.
Re: What are the Problems and Failures That Would Be Hidden in Traditional Relays?
11/05/2016 2:06 AM
Rude
Good Answers: 181
11/05/2016 9:30 AM
I haven’t seen any post by regular members that could be classified as “rude”
Try asking other sites to do you’re homework, you’ll find out just how rude engineers can be.
11/05/2016 2:10 PM
No-one else here has a problem with that.
11/05/2016 8:08 PM
ask a silly question get a silly answer
..ask a good one..
ask a rude one...
engineer a better question and get a better answer
Good Answers: 116
11/06/2016 1:23 PM
Define what you mean by "hidden failure" ....... you might get a better answer.
Real failures are never "hidden" - they are visible burnt & damaged equipment.
Sometimes there is no annunciation or operator observation to explain why the system tripped and no detectable damage....that is a failure to deliver ideal continuous power.
11/27/2016 9:37 PM
I think one hidden failure or problem that you may encounter in traditional relays are the flexibility of these relays when adopting it or employing it in a modern powers system. Since traditional relays has a less functions compare to modern one's also you may want to consider its operating range and coverage in terms of protection zone. Further in terms of space and convenience in installing i think that a lot of traditional relays say 12 relays with a very specific function can be done by a single relay particularly a multifunction microprocessor based relays with lots of embedded function which will save space and time upon installation.
Register to Reply 15 comments
67model (1); Aliyousuf (3); Brave Sir Robin (1); James Stewart (1); JE in Chicago (2); lyn (1); mrbrightside (1); PWSlack (1); Rixter (1); TonyS (2); Tornado (1)
