I'm making some handmade windings for the first time for it's inductance value.
And I was wondering if there are any practical consideration or tips that I should be aware of in the construction?
I've done the usual internet search, and searched through this forum, but I haven't come across much that deals with practical tips on building windings... like how tight to make them, will the L value suffer from windings that are too loose?...etc.
the expected current and voltage lead is V= 13.2, I=3.3, (W= 5.75 * 3 at the peak moments (assuming I have the average lag angle correct)) and I haven't worked out a formula for the mean rate, because the increment rate isn't known due to the set of values used and the unique positions they hold being atypical in circuitry, and so studies haven't been done yet. However, dissipation factors are known, and hence I'm able to work out the peak moments.
I've given as much information as I can at this time, about that.
I want to build a star configuration so that I achieve V=√(3*13.2). simple star inductance really. but perhaps there're some practical considerations that I can be made aware of, by people that may have built windings before?
