Previous in Forum: L-ion Cell Configuration   Next in Forum: Feeder Calculation Help
1/3 in Symmetrical Components
11/16/2016 5:23 AM
Where does this 1/3 comes from in symmetrical components?
Va1=1/3(Va+aVb+a^2VC)
Re: 1/3 in symmetrical components
11/16/2016 6:53 AM
Degrees of freedom, perhaps. Draw a vector in 2D plane and see if 1/2 applies.
Reply Score 1 for Off Topic
Re: 1/3 in Symmetrical Components
11/16/2016 9:02 AM
Here is a tutorial.
Good Answers: 116
11/16/2016 9:11 AM
Sshh...... Questions that look like homework awake the sleeping Gruffalos
There are textbooks with the proof of the theory in them with all the algebra.
My ancient mind is telling me the theory does not just apply to 3 phases and the "3" is because it is 3 phase.
11/16/2016 11:07 AM
"Gruffalos"? I thought it was the Curmudgeonsaurus!
11/16/2016 3:59 PM
It comes in when you solve for V1a, V2a, and V3a in terms of Va, Vb, and Vc. This can be done with 3 simultaneous equations of 3 variables, but it is usually done using linear algebra.
Linear algebra combines the three variables into a vector. The vector of the known values is multiplied by a 3x3 matrix to get the vector of the unknown quantities. If the matrix is invertible, the inverse operation can be done.
If Y=AX, then X=A-1Y
In this case, the magnitude (determinant) of A is 3, so the magnitude of A-1 is 1/3.
The vector of [Va, Vb, Vc]T is the matrix
multiplied by [V1a, V2a, V3a]T as shown above.
To solve for [V1a, V2a, V3a]T, you need to invert the matrix.
The 1/3 comes in when the matrix
which has magnitude = 3, is inverted to solve for Va1, Va2, and Va3.
http://www.wikihow.com/Find-the-Inverse-of-a-3x3-Matrix
http://www.zmuda.ece.ufl.edu/Fall_2013_Power_Systems/6-Symmetrical_Components.pdf
67model (1); gutmonarch (1); Kilowatt0 (1); Rixter (2)
