Previous in Forum: Feeder Calculation Help   Next in Forum: Neutral Shift
Select One of Different Sized Matrices Simulink (PLC Compatible)
11/16/2016 10:20 PM
Hello,
I am looking for a method in Simulink to select between two matrices of different sizes (in this case a 2x3 and 3x3 matrix) which can pass the Programmable Logic Controller (PLC) requirement of fixed size output.
In the example attached, I tried using multiport switch, but it will only work when I enable variable size, which makes the approach incompatible with PLC. I cannot add zeros to make the matrices of the same size, because this will affect a part of my Simulink block downstream. Is there any possible solution/workaround for this method?
PS: I cannot use m-code for this purpose as it is not compatible with the PLC hardware target I plan to use.
Re: Select One of Different Sized Matrices Simulink (PLC Compatible)
11/17/2016 10:03 PM
Well if it's been done you can probably find the method here...
https://www.mathworks.com/help/simulink/slref/selector.html?s_tid=gn_loc_drop
