Previous in Forum: Three Phase Induction Motor and a Two Phase Power Supply?   Next in Forum: Cable Type & Sizing Required For Welding Machines
dc motor
08/10/2007 7:43 AM
i want ot know it principle
Re: dc motor
08/10/2007 7:57 AM
A wire with a DC current flowing in it across a magnetic field is subject to a force perpendicular to the field and current Fleming's * Left Hand Rule.
Use enough wire and get the geometry right ...you have a motor.
*(for UK viewers...that's not Bob Fleming gough splutter)
United Kingdom - Member - Member
Re: dc motor
08/10/2007 8:04 AM
Yeah and I want to know the meaning of life, but I would at least do a search on the net before I posted a question on this forum!
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Re: dc motor
08/13/2007 3:43 AM
Try dismantling a battery-powered toy that contains an electric motor and have a look at the bits. It should become obvious.
Is the value of play and experimentation being under-estimated?
Register to Reply 3 comments
Bolton_Alan (1); PWSlack (1); user-deleted-1105 (1)
