Previous in Forum: IEC Symbol Meaning   Next in Forum: ETAP or SKM or Other EE Software
9 comments
Under Voltage Protection In Parallel Connected Switchgear
12/05/2016 1:47 AM
Dear all,
There are 2 incomers fed from 2 different remote substations to a 11kv panel, the switchboard consists of 2incomer and a bus-coupler, all 3 breakers are normally closed hence both incomers are parallel connected. Is it possible to provide an under voltage protection trip during under voltage in any one of the incomers since both are connected in parallel? the requirement is in case of an undervoltage in any one of the incomer, the respective breaker should trip.
thank you
Re: Under voltage protection in parallel connected switchgear
12/05/2016 4:51 AM
12/05/2016 5:24 AM
The question is how to sense under voltage by an under voltage relay individually when both incomers are connected, because each under voltage relay will read the voltage if there is any one feeder is live, hence there will be a back feed during power outage in any one feeder. the undervoltage will act only when both incomer is in under voltage
12/05/2016 5:33 AM
Er, so what's the problem?
If there is a two-out-of-three interlock between the bus coupler and the two incoming feeder isolators, as is normal on many twin-fed panels, a back-feed cannot occur.
12/05/2016 8:24 AM
No, 2 incomers and 1 buscoupler in the panel is normally closed condition, ie it will act as a single system. the thing is the undervoltage relays provided in each incomer, but the relays will not loose its supply since it is connected parallel. the only option i think the reverse power relay, but its costly. please suggest if any idea.
12/05/2016 8:34 AM
<...please suggest if any idea...>
Er, how about a two-out-of-three interlock between the bus coupler and the two incoming feeder isolators?
<...reverse power relay, but its costly...>
Compare it to the cost of not doing it. Which one gives the better whole-life solution (rhetorical question - NNTR)?
<unsubscribes>
Good Answers: 131
Re: Under Voltage Protection In Parallel Connected Switchgear
12/05/2016 11:51 AM
The simple answer is NO, you cannot do it with just undervoltage relays if you are operating with a dual source, closed tie configuration. The other source that is not sagging will try to maintain the voltage level. What will happen in that case is that current will flow from the other source to the sagging source to try to raise the voltage.
You will need to look at directional current or reverse power relays, or something like that. Hire yourself a good, competent consultant who deals with this, and get the job done right.
12/06/2016 12:27 AM
agree, thanks
Good Answers: 116
12/08/2016 8:19 AM
Definitely directional relays.
Regarding the cost - look at the costs of not providing protection.
If you need both feeders, you have to decide which loads to cut - and how - when one feeder goes low.
12/06/2016 3:23 PM
A sudden unusual flow of reactive power out might be another indicator of an impending problem, where you could isolate based on that. These 3 solutions depend on your history and who owns the power passing through, if any.
Your utility will likely have some guidance on how to disconnect/sectionalize in an event.
Register to Reply 9 comments
67model (1); Anonymous Poster (1); PeterT (1); PWSlack (2); roykav (3); rwilliams (1)
