Previous in Forum: Auto Smart Key Mystery Device Hacks into Cars   Next in Forum: Weird Shadow on Moon
15 comments
The Engineer
Good Answers: 129
Wifi at 10,000 Times Lower Power
12/13/2016 11:06 AM
I thought this was pretty cool...
UW engineers achieve Wi-Fi at 10,000 times lower power
The upside of Wi-Fi is that it’s everywhere – invisibly connecting laptops to printers, allowing smartphones to make calls or stream movies without cell service, and letting online gamers battle it out. The downside is that using Wi-Fi consumes a significant amount of energy, draining the batteries on all those connected devices.
Now, a team of University of Washington computer scientists and electrical engineers has demonstrated that it’s possible to generate Wi-Fi transmissions using 10,000 times less power than conventional methods. The new Passive Wi-Fi system also consumes 1,000 times less power than existing energy-efficient wireless communication platforms, such as Bluetooth Low Energy and Zigbee. A paper describing those results will be presented in March at the 13th USENIX Symposium on Networked Systems Design and Implementation.
Article found here
The technology has also been named one of the 10 breakthrough technologies of 2016 by MIT Technology Review.
Re: Wifi at 10,000 times lower power
12/13/2016 11:26 AM
if I understand the article, the savings is due to an additional layer of technology between the router and actual handheld device by using RF passive technology?
Is there power actually saved, or is it just diverted elsewhere.
12/13/2016 11:46 AM
I would say it is power efficient as in each device in the IoT does not need a large battery to communicate but instead piggy back in the one device plugged in the wall.
12/13/2016 11:55 AM
That's how I understand, the power is moved to where power is more available.
Which makes sense. I rather that, that put a drain on my batteries.
12/13/2016 2:51 PM
Here is the way I understand it:
They move the analog part of the processing to the router which is plugged in. The IoT devices themselves apparently send data by just switching the impedance of an antenna which modulates the reflectivity.
The claimed data rate is 11 MB/sec.
It's the same principle as communicating with flashing lights. You could have a light source at both ends or a light source at one end and toggle a mirror at the other.
12/13/2016 3:09 PM
Clever technique. Reminds me of a very different application: sending data back up through a drill string by modulating the flow rate/pressure of the drilling mud. They used a heavy, six-vaned tungsten carbide shutter near the bit end that would alternately cover and expose corresponding holes through which the drilling mud flowed. Very low data rates of course both because of mechanical limitations of the shutter but also because the mud column is extremely noisy in terms of pressure fluctuations. Terrible SNR which required advanced techniques to extract the data from the noise (something having to do with Bayesian statistics as I recall).
The data consisted mostly of the string electronic's basic vital signs, the bulk of the measurement data (rock resistivity, 3-axis magnetic field, neutron backscatter data to measure rock density, etc.) being saved on-board in RAM (that has to reliably withstand 200C temps and extreme shock and vibration) They measure and store a boatload of data in those strings and then download it to the rig's computers when they pull the string out of the hole.
12/14/2016 4:42 PM
Hey - that's encroaching on the wireline industry. What next? Perforate as they run casing?
12/13/2016 3:18 PM
Got it...
Re: Wifi at 10,000 Times Lower Power
12/13/2016 1:27 PM
Hey, they should come here and test their wares. My Internet provider has offered this service for years!
I sometimes wonder if I'm paying more for the promise of Internet connectivity here than the actual fact of it. Was downloading the latest Mint Linux distro for instance and the initial ETA for the 1.2 GiB file was 4 years, 47 weeks. Be still my heart.
12/13/2016 1:53 PM
Very impressive that they can achieve 11 Mbps with a few microwatts. What's the error rate I wonder? Usually they have to reduce bandwidth at lower power to minimise errors. On the flip side connected devices not requiring all that bandwidth could operate at greater range.
12/13/2016 1:57 PM
So in reality....
What we will get is new devices that use 1/10,000th the power but they will put a battery in them that's 1/10,000th the size so we will gain nothing for overall run time.
Sounds way too plausible to me to not happen.
12/13/2016 2:06 PM
Some devices contain no batteries at all - nor need them - deriving their power instead from the signal itself. Many RFID devices do this, for example.
12/13/2016 3:17 PM
that would be the term passive RF comes in
12/13/2016 3:25 PM
Exactly (although some readers - none here I'm sure - might read 'passive' as their being especially apathetic. "Oh gawd, not another signal." ).
12/13/2016 6:38 PM
Or they might have a solar cell and rechargeable battery like solar powered watches.
12/13/2016 9:14 PM
Cold fusion.
Register to Reply 15 comments
Andrew Westman (6); phoenix911 (4); Phys (1); red_fish (1); Rixter (2); tcmtech (1)
