Previous in Forum: Shower timer   Next in Forum: Switching Regulator System.
11 comments
GPS Antenna - repair
08/12/2007 8:23 AM
GPS Internal Antenna
A crew member stepped on the antenna of a Navman 5500i GPS Plotter and broke off the internal antenna. I have approached the manufacturer and they refuse to sell parts directly but do have a service department that could be used. The estimate and the part seem to make it not economically reasonable to go that route.
Since the antenna is 'quite messed up' if anyone would have an idea of the schematic for the antenna I would happily undertake the construction project. Even better, it if there was an antenna from an other broken similar unit or information on how to convert the unit to an external antenna that would be fabulous.
Thanks for your thoughts.
Brian
Pathfinder Tags: antenna GPS
Re: GPS Antenna - repair
08/13/2007 1:11 AM
Do a search on 1.575 ghz antennas. All gps recievers use the same freq. This is a fairly high freq to cut an antenna accurately, you might find a fit from other manufacturers. Usually they employ a BNC connecter, if your unit doesn't use one, I would rather find an adapter than change the one on the antenna end.
08/13/2007 1:52 AM
Many thanks and I'll dig into the approach you suggest. I believe I can salvage the actual antenna (the box on the top) with the etched radials so it might be possible to move ahead on this.
From what I can gather there appear to be a couple of capacitors on the connecting board but they appear to be shorted - not surprising having been stepped on. There currently is no external antenna connector so if I used coax to go from the original internal antenna connections to the back of the case to a BNC we might get lucky.
Again many thanks for your time and thoughts.
Brian
08/13/2007 3:59 AM
Use 50 ohm coax, there are many types, go to an electronics supplier and they should be able to help you. This was kind of interesting:
http://www.cvisproject.org/download/Deliverables/DEL_CVIS_3.1_Reference_architecture_v1.2.pdf
08/13/2007 9:03 AM
Thanks for that.
I have done some ham radio stuff and feel good about tackling this one. I do appreciate the early cautions and direction for the project. Once completed, I'm certain a certain crew member (sailor) will feel a lot less obligated to dig deep into the pocket.
I'll let you know how it's going.
Brian
08/13/2007 10:06 AM
Go to EBAY.
Search for GPS Antenna.
Many available for hand-held, auto and marine use.
CHEAP!
Put a matching connector on your Head Unit.
Back in business.
Throw offending crew member overboard.
08/13/2007 11:14 AM
I'll have a look at that solution - both of them!
Prior to a race from time to time we do have to check for weeds on the prop . Hope he can swim!
Thanks
Brian
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
08/13/2007 11:27 AM
Brian,
Here is an article from QST magazine on a simple GPS antenna you can build cheaply. Even if you don't build this antenna, the construction tips might help you in hooking up you coax and connectors to the leads of the broken antenna.
http://www.arrl.org/tis/info/pdf/0210036.pdf
"What, me worry?" Alfred E. Neuman
08/13/2007 12:56 PM
That's great. This is the first time I have asked a question on the board and the response has been wonderful.
Much appreciated.
VA3BS
09/07/2007 4:19 PM
I built the antenna and it worked like a charm. Locked onto 8 sats very quickly and I believe faster than the original internal antenna. Knowing this works fine I think I'll look into an amplified external antenna, mount as SMA (F) on the gps and we're set to go.
Thanks so much.
Brian
PS: an engineer at Navman told me he hooked an alligator clip onto a quarter, placed the wire into the SMA (F) on the gps and it worked. Guess one could make a few $ on this bet.
09/07/2007 4:26 PM
"an engineer at Navman told me he hooked an alligator clip onto a quarter, placed the wire into the SMA (F) on the gps and it worked"
If you want a cheap solution, I guess that one really is a "Two-bit Antenna"! <grin>
05/19/2008 7:29 PM
I have been reading the mail with great interest on this thread and I hope you can help me with my GPS antenna challenge.
About four years ago I bought a NAVMAN 5500I (Internal antenna) for my 27' cruiser. It worked well while I owned that cruiser. However, the two footitis got to me and I jumped to a 1966 36' Christcraft and I immediately upgraded my new toy, one of which was to replace the canvas. It seems that the canvas was such a good quality that the sat signal to the GPS was very weak and at times not existent. I moved the GPS closer to the plastic window where it works fairly well but as you can guess, out of visual range.
I have been seriously contemplating installing a coax connector on the GPS thereby bypassing the internal antenna to an external antenna.
I have reviewed some of the articles that were discussed in the thread, ie QST and encouraged that this is possible.
Can anyone advise, first, is it possible and secondly, if it is, is there any advise or technical data available to guide me?
Thanks,
Maj
Register to Reply 11 comments
Anonymous Poster (1); Maj (1); Perkins (5); possien (2); STL Engineer (2)
You might be interested in: GPS Instruments and Modules, GPS Chips, GPS Software
