Previous in Forum: Young India Celebrates 60th Independence Day   Next in Forum: Pore Size of Coffee Filter Materials
10 comments
Spherical/Cylindrical storage tank which to choose?
08/14/2007 2:33 PM
Few years back in an LNG plant I worked, I observed that ethane was stored in horizontal cylindrical tanks and propane was stored in spherical tanks. and a process trainer asked the question why? I couldn't say for sure, but I thought it has to do with vapour pressure considerations. Anyone with viable ideas?
The next time you feel like saying something stupid............ don't.
Re: Spherical/Cylindrical storage tank which to choose?
08/15/2007 2:03 AM
Hallow,
Many a time it is on account of availability of space and requirement of inlet,outlet etc. connections.Of course cylindrical tanks r easy to fabricate.
Second thought:- Cylinders of different geometrical shapes breaks monotony at work place.
Rajeev Kumar
Good Answers: 88
08/15/2007 2:10 AM
If you're really ambitious, you can paint smileys on the round ones.
South Africa - Member - ShoSholoza Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member
08/15/2007 2:25 AM
From what I understand, it seems to be an economical choice as spheres can be constructed from thinner plate than cylindrical vessels as the volume increases.
Can you imitate yourself?
08/15/2007 2:40 AM
ethane cant be stored in spherical tank insteade of it will be internal floating with nitrogen pressaurised. ethane can only stored in horton sphere or in bullet.
Good Answers: 88
08/15/2007 2:56 AM
Yes, but why?
Good Answers: 137
08/15/2007 4:56 AM
To echo Europium in #6, why?
Is it a general rule or just happened to be the case on the site where Telesky was working?
Propane has high critical temp 96.8°C so stored as liquid under pressure in the tank, vapour pressure 9 barg at ~ 26°C. I expect ethane (critical temp 32.2°C) has to be stored as a gas (correct me if I'm wrong) so high pressure needed to reduce tank volume.
So if anything you'd think ethane would be in spherical, propane in cylindrical, not vice versa. Though if designed properly, in principle either is OK.
Codey
Good Answers: 101
08/15/2007 3:55 AM
Hoop stress in cylindrical tanks = (pr)/t.
Longitudinal stress in cylindrical tank = (pr)/(2t).
Hoop stress in spherical tank = (pr)/(2t).
where p = internal pressure of tank.
r = radius of tank.
t = thickness of tank wall.
Based upon the above considerations, either it's because propane is stored under higher pressure, or it vaporizes more readily and will thus exert more pressure upon vaporization.
08/15/2007 8:30 PM
if i recall propane is a heavy gas and is stored in liquid state at a lower pressure than ethane lighter gas to keep in liquid state -180c you need a thermos bottle so you just compress it in a thick wall bottle
08/15/2007 9:03 PM
i goofed ethane gust requires a thicker wall bottle because of the higher pressure needed to store it
propane boiling point -42c
ethane boiling point -86c
08/16/2007 11:06 AM
While a sphere is intuitive for any pressure vessel....
Large spheres with thick walls are difficult to stamp. Many more fabrication shops can roll a cylinder and make or buy the heads. CBI and only one or two others were doing the thick (<2 inches) spherical sections in the US, last I heard.
Register to Reply 10 comments
Anonymous Poster (3); Codemaster (1); DVader1000 (1); Paddler (1); Rajeev Kumar (1); The Hammer (1); user-deleted-13 (2)
