Previous in Forum: Spherical/Cylindrical storage tank which to choose?   Next in Forum: Was Man evolved only on earth and by only one thread?
Good Answers: 18
Pore Size of Coffee Filter Materials
08/14/2007 3:09 PM
Can anyone provide the pore size information for the typical range of filter paper materials made into coffee filters (or tea bags)? I have been wondering for some time whether it might not be practical to use such filter paper materials to form packets of adsorbents (to be used in small systems) for removal of arsenic, etc. in contaminated water in 3rd world village settings. Water would be filtered through the bags containing absorbent to remove chemical impurities. Obviously it woulld be used in series with a sand filter or other to remove bacteria and other parasites.
Good Answers: 101
Re: Pore Size of Coffee Filter Materials
08/15/2007 4:11 AM
Average pore size range for coffee filters is from 5 to 100 microns.
08/15/2007 4:33 AM
Is there a catch here,? I thought charcoal was the accepted solution, or doesn't it deal with arsenic?
Wish I was here more often.
Good Answers: 18
08/15/2007 10:54 AM
Charcoal is an acceptable method for removal of organics. Arsenic is metallic and is adsorbed onto certain iron oxides (eg: rusty nails, or iron ore fines). Controlled packaging of iron oxides in such filter packets could provide a means to remove arsenic and simultaneously filter the water of pathogens if the filter paper were of appropriate size to remove the biologicals (typically ~1-2 microns). Similarly, any other adsorbent could be packaged for removal of other pollutants.
Currently, P&G has marketed an emergency system for water purification (that comes in packets) to remove bioloical pathogens. I believe it is called PUR and I think it uses appropriate quantities of Calcium Hypochlorite and an iron based coagulant to treat the water.
I am looking at what might be done to remove chemicals and trace hazardous metals from contaminated water often used in poor villages. This would be a way for providing a more "controlled" or guaranteed means for arsenic (or other materials) treatment of the water and would be simple to produce at low cost.
08/15/2007 1:12 PM
Arsenic in groundwater is frequent found in a reduced state as a cation associated with sulfur anions, e.g. sulfide. This is a soluble form. By oxidizing it to anionic form and reacting it with certain metals, Iron is a good example, it precipitate out the arsenic to form a metal arsenic precipitate. This can form on the surface of the metal or in solution.
Register to Reply 4 comments
agua_doc (1); Anonymous Poster (1); DVader1000 (1); Wrenched (1)
