Previous in Forum: Pore Size of Coffee Filter Materials   Next in Forum: The grid?
23 comments
Was Man evolved only on earth and by only one thread?
08/15/2007 1:56 AM
Consider this: If a species evolves over billions or milllions of years, there must have been many million or trillions of mutatations to get from specie a to specie b . (IE ape to man). Where are all these other millions if not trillions of mutated species (near look alikes many of them and other farther apart and still other still farther apart in appearance.) What we are seeing is very few of what fossil evidence should be there.
How can lack of fossil evidence be explained? Is it concievable that perhaps man evolved on a much much much larger rock than earth and that billions of years ago this giant planet split apart and cast bits and pieces of itself and different pieces of fossil evidence across the universe in doing so? IF so perhaps our little splinter piece of the larger puzzle was not the prime ground for our own evolution? That might explain the huge gap in the evolutionary fossil evidence that should be there in the millions of varieties of mutations that had to occur to get us here.
Otherwise if we think that all humans everywhere in the universe originated here and only here aren't we being very shortsighted? The earth isn't flat either is it. An objective logical situation is that there must have been an origin giant planet and we are only a tiny splinter of it and also there then must also be somewhere in the universe other "human like" beings. Maybe some of them have extra featrures like extra limbs because that worked well enough for therm over the eons of evolving for survival etc.
If like some would have us believe there is only the earth only evolution then because there is only one type of man (basically with minor differences) then there must have been some miraculous thread the LEAPT the Fossil Evidence Gap and only left a very few of only one type of mutated variant from the ape. That to me seems very statistically impossible unless some other external driving force caused that to happen. ( A miracle.)
This lack of fossil evidence can also question the lack of millions of variants for really every animal. In other words there should be elephants with 3 ears because after all 3 ears are more conducive to survival than just 2 or 1 right? There is a great LACK of fossil evidence on this planet. We are not the center of the universe and are probably" only a very tiny sliver of what was. Ok .. tell me if this is impossible.
If man evolved only on the planet earth then it must be by at least least or more "leaps" of the "Gaps" in the evolutionary process from perfect ape to perfect man. Or at least in only one or two threads of specie with giant leaps compared to what should be there in fossil evidence.
NOTE: By "Gap" I don't mean in the thread that led from ape to man but in the fossil evidience that should be there in the millions of "varieties" of "Transition Man" that statistically should be there. (Although there is some gaps in the thread as modern day darwinians explain evolution by one and only one thread and only on this planet only).
THE QUESTION: Are we from a single mono thread of evolution and from only our own planet or is the other case more likely?
Peace begets Synergy which begets Progress!
Pathfinder Tags: "missing link" darwin evolution fossil evidence
User-tagged by 1 user
Re: Was Man evolved only on earth and by only one thread?
08/15/2007 2:47 AM
Lack of evidence is being eroded as time goes on and we find more fossils. Also we are going 'back' and reexamining fossils and coming to different conclusions. We have barely scratched this ol' earth looking for fossils. Tectonic plate movement, volcanic occurances and glacial eras have a tendancy to 'erase' some of the fossils. Elephants do not have three ears becuase there is no survival need to have three so they did not evolve them. No our planet was not part of a mega world that blew up into smaller worlds, kinda leaves it rather tough for anything to survive. yes we did evolve from a common ancestor if you go back far enough and as we find more fossils to link together the chain. After all evolution is simply a species adapting it's form to survive the enviroment it lives in. With some mutations thrown in from possibly to much radiation in the soil due to radioactive materials being close to the surface and/or heavy solar radation. This planet has not always had enough protection from solar energy not to mention higher than 'normal' solar storms and flares.
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
08/15/2007 3:18 AM
The lack of fossil evidence isn't a surprise, it's the fact that we have much at all that's surprising, considering the time scales involved. For example, everyone thinks they know what a T Rex looks like, and probably thinks it's a common fossil. In fact there are only 7 T Rex skeletons known (unless more have been found since I last checked) and only 1 even nearly complete. The fossil record only confirms the theory of evolution. What you want, I suspect, is to debunk the theory by pointing out the inevitable gaps and saying 'we cant be sure!' If you want to debunk the theory of evolution using fossil's, you need to find a fossil rabbit in the Cretaceous period strata.
As for the millions of mutated species, look around you! Everything alive today is a success story. It's made it through deep time and is still alive, so each change that has occurred has been, by definition, a success. Also, the ones that have not made it were not necessarily failures, but likely couldn't adapt to environmental changes fast enough. Or, if you prefer, could not mutate fast enough. Thats what Darwin meant by the mutability of species.
Interestingly, the latest idea's are that after each major extinction, think the end of the dinosaurs for example, there has been an explosion of species to fill the vacant evolutionary 'spaces', and the belief is that our ancestors broke away from the other primates at the last minor extinction event. (The last 'major event was the KT or Cretaceous-Tertiary extinction event)
Our latest estimate is that 90% of all species that have ever lived are extinct. Bear in mind that we know of at least 350 thousand species of beetle alone, and that they are the size of most of the species missing from the fossil record, and you should have an idea of the scales involved.
And by the way, we DON'T rely solely on fossils to confirm evolutionary theory.
A gap in our knowledge should be regarded as an opportunity to research and increase our knowledge, not used as a crutch to try and discredit all we know after years of hard work.
'The truth is out there' The lies are in your head.
08/17/2007 1:16 PM
Actually no you are wrong. No one of us is trying to "debunk" evolution. Many told einstein that he was trying to debunk all the theories of his day but in reality he actually accommodated the old theories into a new an better more comlete more encompassing (More Robust) theory. Its the same here.
Again, saying that the earth is the only part of the universe that had the ape--> man evolution is statistically impossible. Think of earth as a tiny tiny speck of dust on your porch. You are asking us to take that tiny speck and show a complete fossil record for all of the rest of the earth. Thats the size of earth compared to all of the rest of the universe.
Thus the gaps both in the forward one or two threads for ape-man evolustio that you do find here and the gaps in the lack of massive fossil evidence for the millions and billions of years of evolution for all the trillions of different types of species and the millions of transition types that mostly lived for some time and then failed, are both too much to ignore. And more interestingly are the T-man transitions from one specie to another ie ape==> man.
Again there should be at least 1million different mutations statistically speakeing for each creature we find here on earth. The only logical explanation is what the big bangers have been saying ; we are but a tiny speck in the universe and thus we must also have only a very tiny speck of the fossil records as well.
Hope this helps you . No one is trying to make you a believer in miracles or to debase your beliefs. But we must not be narrow minded and see ourselves as the origin of all life in the uinverse. Thats my theory! I will pubish it someday. If you can dissprove it please do so. FYI: Those who do in fact believe in a one thread only transition from one specie to another are actually using "Faith" to provide the bridge of the 2 gaps described above. That "faith" is actually a form of religion. Suprising isn't it.
08/18/2007 7:07 AM
Sorry, yes; I must have misunderstand your intentions. As to life away from our lonely outpost in the unfashionable part of the milky way, I think it would be the height of arrogance to believe that we are the only life in the universe. It has been said that the chance of life developing is remote in the extreme. That's still a figure that is huge in comparison with zero. If the fossil record has taught us anything, it's that life is extremely tough, it's survived (on earth at least) everything a mostly hostile world and solar system could throw at it, including that period known as snowball earth. Are we alone? I don't think so. Would we even recognise otherworldly life? Who knows, if at some point 6 million years ago, our distant ancestor had gone down that evolutionary path rather then this, would we look as we do know? Almost certainly not! ( For a start, this keyboard would be a different configuration to cope with my sixteen finger's and 40 letter alphabet!) I hope this clears that up!
08/15/2007 3:35 AM
One only has to look at the avatars in CR4 to find them....
08/15/2007 3:44 AM
That's true, I've been extinct for years!
08/15/2007 3:48 AM
There's also a Star Trek problem: all higher-level life forms are perhaps assumed to be humanoid, because human actors have been needed to play them (apart from the Horta). There is possibly an assumption that humanoids are the most advanced life forms available, which may not necessarily be true due to a lack of communications, though SETI is working on it.
Should the human continue on its path towards extinction then other life forms will evolve to supersede it. What about bats instead?
Interesting topic! Could boldly go where no-one has gone before...
08/15/2007 3:56 AM
My money's on the cockroach, they will survive the end of the world 99 times out of a hundred.
08/15/2007 4:09 AM
Seems they died.
Wish I was here more often.
08/15/2007 6:05 AM
I'm sure the 3 eared Elephant illustration was meant to be funny...but.
No! 3 ears are not better than 1 in terms of directional location, especially when there is some control over the ears (mine waggle independently in a most fetching and catly manner ideal for locating rodents)
There is also nowhere sensible to mount the 3rd ear without compromising other functions. Maybe stick it above the arse?
08/15/2007 6:13 AM
Reckon you'd soon find yourself up against a 3-eared rodent requiring triplicate stealth.
08/17/2007 4:59 PM
Actually concerning the 3 eared elephant I could've said a one eared (or 10 legged for that matter) to which you would answer two are better than one. Same logic for 3 better than 2.
In fact GPS proves that.. 3 references provide more exact locational data although 2 give you a less approximate location. Yeah.. and where are all the creatures with an eye in the back of their heads. Thats for sure early warning if I ever heard of it and logically much more surviveable. Still looking for Dem Bones Dem Bones... Dem Fossil Bones! We are but a tiny tiny speck of dust in the universe of matter.
08/17/2007 5:33 PM
No that doesn't follow ...if it did then 100 is better than two and 1000 better than 100...this is just wooly thinking.
No three isn't better.
Consider pradator and prey.
A cat knows where it is looking for prey and has two directional ears it can adjust to search in the area of interest.
A rabbit may be attacked from any direction (including above) similarly it has two directional ears with which it can scan the surroundings over the danger area. This combination of two directional and controlled ears gives perfectly adequate and accurate information. A third ear would not help.
If you had argued for any number of ears I would still argue for two.
United Kingdom - Member - New Member Hobbies - Model Rocketry - New Member
08/15/2007 9:24 AM
Wow, a whole mess of misconceptions leading to a hypothesis based on no evidence whatsoever....
Can I vote this thread off-topic? Maybe we should ask the moderators for a "pseudoscience button".
The yoke a man creates for himself by wrong-doing will breed hate in the kindliest nature . . .
08/15/2007 10:24 AM
Which bit?
United States - Member - New Member Engineering Fields - Biomedical Engineering - Biology, the most elegant Engineering Popular Science - Biology - New Member
08/15/2007 1:08 PM
Consider that there are 50,000 to 140,000 genes in human DNA, and humans and chimps, 2 different species who share common ancestry share >98% same genes. So at most they differ by only 1,000 to 2,800 genes. Many species are even more closely related. So your estimates of millions or trillions of mutations to get from one species to another are way too high. Also, there is no lack of fossil evidence. Fossils of hominids that are in between homo sapiens and our "ape-like" ancestors have been found so there is no "missing link" anymore. I think given the vastness of space and the amount of time needed and difficulty to cross it that the probability that life started elsewhere and moved here to be much lower than it started and evolved here.
08/16/2007 3:02 AM
Well put!
08/16/2007 5:04 AM
Does this reflect on another thread about human space exploration. Is the liklihood of any of us ending up on other planets equally slim?
Do I unpack?
08/17/2007 8:21 AM
It depends, Is your glass is half full or half empty?
08/17/2007 8:41 AM
My glass needs filling, to the top thank you, and I want a bigger glass!
08/17/2007 1:43 PM
Good question! How many different combinations of 2800 genes are there? 2800x 2800 = 7.4 million right there alone. What is 28002800 ( to the 2800 power)? Is it trillions? But even in the lowest (wrong estimate) where are all the fossils from 7.4million - the one miracle thread that made it to us? So you see its way to statistically impossibel for there to be only one or two threads and also there has to be fossil evidence to support all the 99.999 % extinct versions that maybe only lasted a few thousand years or less.
08/17/2007 4:25 PM
You're confusing gene types with gene variants and phenotypes with genotypes so your reply makes absolutely no sense. If you're going to talk science please learn something about it.
08/19/2007 12:24 AM
If you perhaps know everything about genes and the tremendous trillions of combinations how come we never heard of you before?
Register to Reply 23 comments
Anonymous Poster (1); Irving (3); PlbMak (7); PWSlack (2); Silas Marner (1); TRIPLEBATTERYLIFE (4); user-deleted-1105 (2); Wrenched (3)
