Previous in Forum: hydrocarbon dewpoint calculation   Next in Forum: Telescopic pipe
13 comments
Liquid Pump
08/14/2007 5:17 PM
Can any one tell me where it is made Available ?
Liquid Pump to operate on 6/12 V DC
Tube Inlet/outlet 3 mm; 6 mm ; 10 mm ; 15 mm Dia
Capacity 1 Lit/hour to 3 L/hr ; 3 - 10 L/hr ; 10-20 L/hr
Pressure 1 atam to 5 atam; 5-10
Rating Continuous
Engg Design, 150 hp/1000 cc, 1600 hp/2400 cc F1; 600 kph MonoRail,Ferry,VLCC
Pathfinder Tags: small pump
Re: Liquid Pump
08/14/2007 6:16 PM
Search for peristaltic pumps....you should find ones which can do all that...maybe the pressure is a bit high....4atm is eay enough to find.
Safety - Hazmat - New Member
Re: Liquid Pump
08/15/2007 2:58 AM
Dear sir,Contact MILTON ROY,HIDENBERG FLUID DOSING
Re: Liquid Pump
08/15/2007 3:51 AM
A car windscreen washer pump might be appropriate for the smaller sizes, assuming the pumped fluid is water?
Re: Liquid Pump
08/15/2007 4:12 AM
You missed the continuous rated bit ! They burn out v quick if you leave 'em on... .
peristaltic pumps in Uk (that's me that is )
Re: Liquid Pump
08/16/2007 8:47 PM
YOU HAVE MISSED IT
IT IS THERE !
Re: Liquid Pump
08/15/2007 11:22 PM
Instead of a windshield washer pump, how about an external (outside the tank) automotive electric fuel pump. They run for years, can be had to deliver almost any pressure and volume, and most are 12 volt.
Re: Liquid Pump
08/16/2007 1:10 PM
We all tend to forget simple solutions!
Re: Liquid Pump
08/16/2007 8:49 PM
WHAT IS IT ?
Re: Liquid Pump
08/15/2007 11:26 PM
Not sure about the flow and pressure but I would look in the RV area. They are US standard fittings and you will have to check other spec.
Tom
Re: Liquid Pump
08/16/2007 12:43 AM
There are multiple manufacureres of dosing pumps capable of handling any solution. Try grundfos, jesco, surflo, for a start
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Re: Liquid Pump
08/16/2007 6:14 AM
What's the liquid?
Re: Liquid Pump
08/16/2007 9:06 PM
TAKE IT AS WATER, PETROL, DIESEL, CRUDE OIL, ETHENOL, LPG, LH2 ,
AVIATION PETROL
NOT SLURRY
Re: Liquid Pump
08/16/2007 9:16 PM
HOW ABOUT A [ AIR OPERATED] PNEUMATIC PUMP ?
Register to Reply 13 comments
appan (4); coconutpete (1); fliptop427 (1); hilltopper (1); HydroScot (1); MUKULMAHANT (1); PWSlack (1); user-deleted-1105 (2); vsankar (1)
