Previous in Forum: absorption a/c   Next in Forum: Were to find those little water damage stickers in cell phones.
hurricane vs. typhoon
08/15/2007 10:49 AM
difference between hurricane & typhoon?
Pathfinder Tags: hurricanes
Re: hurricane vs. typhoon
08/15/2007 10:53 AM
I always heard that a hurricane was Atlantic, and a typhoon was Pacific, but that may just be folk knowledge. I'm not looking it up to see.
Friend of CR4
08/15/2007 11:03 AM
There are some pretty good explanations here:
http://cr4.globalspec.com/thread/2304/Hurricane-vs-Typhoon
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
08/15/2007 11:04 AM
08/15/2007 11:35 AM
Hurricanes are seen on land while Typhoons are seen at the ocean (at least for those spaking Spanish)
Good Answers: 101
08/15/2007 11:00 PM
Regional names: hurricanes occur in the Western hemisphere, while typhoons occur in Asia. In the Indian Ocean, they're known as cyclones.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
08/15/2007 11:28 PM
A little perspective from a weather guy (storm spotter):
Hurricanes and typhoons are large, damaging cyclones that originate in the tropics. A cyclone is a synoptic scale system where winds blow in towards a low pressure center. The winds will turn counterclockwise in the Northern Hemisphere, and clockwise in the Southern Hemisphere. A cyclone usually produeces rainy or stormy weather.
When a low pressure center first forms over a tropical ocean, it is called a tropical disturbance. If it strengthens sufficiently, it becomes a tropical depression. The next stage of development is the tropical storm. These different levels are defined by pressure readings at the surface at the center of the system.
Storms are usually named when they reach tropical storm status.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
08/16/2007 1:17 AM
These terms are both disambiguations for what should be correctley called a tropical cyclone
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Register to Reply 7 comments
3Doug (1); bhankiii (1); Chris Leonard (1); coconutpete (1); DVader1000 (1); PWSlack (1); r&ddoc (1)
You might be interested in: Eddy Current Probes, Machine Vision Systems, Chuck Jaws
