Previous in Forum: Reverse motor with break angle grinder handheld   Next in Forum: CO2 oil well injecting works
Heating air
11/15/2005 9:21 AM
I'm a mechanical engineering student. I want to know how can we heat large volumes of air to high say 1500-2000K temperatures using electricity.
heating air
11/15/2005 10:26 PM
hi, But you have not menstioned whether you want to heat ait in chamber? I think it is possible to heat it a chamber only. For that you have to install a electric heater of the appropriate capacity in the chamber and circulate the air in the chamber with help of air circulating fan. It is adviced to install a temperature controller to contol your temperature at the desired set point.
Friends are the angels, who lift us to our feet when our wings have trouble remembering how to fly.
Re:heating air
11/17/2005 1:42 AM
hi, thank you for reply. i also meant heating in a chamber. according to second law of ThermoDynamics, a heat pump would do a better job than a heater.can you please specify which type(specifications (for say 20 kg/s of air)) of heaters/heat pumps would be efficient.
Good Answers: 19
Re: Heating air
01/17/2007 3:09 PM
Specify volume of air and what Product you need to heat. Is your heating chamber batch type or continuous.
Register to Reply 3 comments
ducon (1); Sonu (1); t d mahesha (1)
