Previous in Forum: Automatic Transfer Switch   Next in Forum: PT Connection
10 comments
Problem Transmission Line in ETAP
04/24/2017 7:01 AM
i have this error message in etap transmission line
(the conductor/wire y coordinate should not be zero)
any solution?
Re: problem Transmission line in ETAP
04/24/2017 7:03 AM
Er, try making it non-zero?
04/24/2017 1:52 PM
it is already not zero but i have the same problem
04/25/2017 4:32 AM
Well, the problem cannot be seen from here, nor can it be determined from such meagre information. The original posting is nonsensical:
  • If it is non-zero, then why is there an error message that says it is (rhetorical question - NNTR)?
04/25/2017 4:59 AM
ok if you can help me how can i calculate the positive, negative and zero impedance for a 150/25 transmission line it is ACSR type and all data i have the resistance at 20c 0.1939
04/25/2017 5:24 AM
By overcoming the nonsense in the first instance.
Good luck with that.
<unsubscribes>
Good Answers: 445
04/25/2017 1:29 PM
The easy way to do this is to go to the web and search for the ACSR conductor tables published by the major suppliers. You will also need the physical configuration of the conductors, height above ground, distance(s) between conductors and shield wires, whether they're transposed, length, doubled, etc.
Re: Problem Transmission Line in ETAP
04/24/2017 10:56 AM
04/25/2017 5:00 AM
not helpful link
04/25/2017 5:32 AM
See page 24 of this pdf:-
https://etap.com/docs/default-source/what's-new/etap-16-getting-started.pdf
Does the error appear in this format, with an error number like this example 706-01?
Or does the error display in some other way?
Good Answers: 42
04/30/2017 10:48 AM
At least the rated voltage and number of parallel circuits on the same tower is required in order to design a possible overhead line.
Julius
Register to Reply 10 comments
7anoter4 (1); muhammadhamdy (3); PWSlack (3); RAMConsult (1); Randall (1); SolarEagle (1)
