Previous in Forum: Grounding Rod   Next in Forum: Fault Locating Feature with SEL Distance Protection Relays
12 comments
I Need to Understand Some Installation Terms
05/21/2017 5:02 AM
Can anyone please explain to me the main cables and sub main cables.I searched in google and I get a lot of wierd answers
Good Answers: 120
Re: I need to understand some installation terms
05/21/2017 6:42 AM
Installation of what? and where?
Per Ardua Ad Astra
05/21/2017 8:25 AM
Main Cables:- Large wires carrying electricity from one place to another.
Sub Main Cables:- branch conductors/wires connected to a main.
Re: I Need to Understand Some Installation Terms
05/21/2017 10:58 AM
For example, say you've a property consisting of a house and an outbuilding. The cable coming into the house's breaker panel is a 'main' cable. The cable going from there to the outbuilding's breaker panel is a 'sub-main' cable.
Good Answers: 70
05/21/2017 11:08 AM
In residential wiring, you may have 1/0 AWG (67.43mm2 ) feeding the service panel and #12 AWG (3.3mm2) branching off in a daisy chain feeding the sub-circuits.
05/21/2017 11:37 AM
Isn't the latter technically a 'branch circuit'? I would think a 'sub-main' cable terminates in distribution panels at both ends.
05/21/2017 3:13 PM
Not in the UK. 3.3mm2 cannot be had here, as it is a non-standard size in any conductor material, and there are no pre-calculated solutions for this particular conductor size whereas there are for other sizes. 1, 1.5, 2.5, 4, 6 and 10mm2 are typical sizes in copper. Usually, 2*4mm2 is the most that can be fitted into the receptacle on the rear of the outlet/switch/socket/whatever whereas the larger sizes will be attached to heavy load appliances such as cookers and power-showers using a non-insertion method of fastening.
The "tails" coming from the meter to the dis' board would usually be 16 or 25mm2 copper, usually double-insulated singles.
However, there are other solutions that will respond affirmative to calculations as regards suitability.
05/21/2017 1:26 PM
Off-topic, but I sometimes have a problem trying to rationalise some members names.
05/21/2017 2:58 PM
It's like countries having the word 'Democratic' in their names, aren't?
05/22/2017 8:56 AM
I guess you have to look at it as a goal and not a title.
05/21/2017 2:43 PM
Yes. A qualified Electrician can do this.
One won't find qualified Electricians by the name of Google. One will by using the local telephone directory.
05/21/2017 3:53 PM
Read up on your local electrical codes and standards, the answer is there.
05/25/2017 5:02 PM
If you are having trouble understanding the Google results you should either take some courses to get a license or hire a professional.
Register to Reply 12 comments
Alanvaderi (1); Andrew Westman (3); aurizon (1); dj95401 (1); jack of all trades (1); JohnDG (1); phoenix911 (1); PWSlack (2); wmerryall (1)
