Hello all. Thanks for taking up your time to read my post.
I obtained schematics and build instructions for a device which generates low current, high voltage (50-100V) signals. The high voltages are generated from a normal 5V USB supply.
The instructions specify to get a 390µH fixed inductor (the PT12133SL as the datasheet of http://www.kynix.com/uploadfiles/pdf8798/PT12133SL.pdf to be precise), and wind magwire around it 16 times. The ends of the inductor are connected to the high-voltage section, and the ends of the magwire are connected to the input signal (0-5V).
This implies that the inductor is acting as a transformer (assuming the instructions are correct). That makes sense, since in some sense there's a winding on the inside (the inductor's winding) and a winding on the outside of a magnetic core. But I've never seen a transformer constructed this way.
If this is in fact a legitimate way to construct a transformer, then (a) how can I compute the transformer's voltage ratio (given that I don't know how many turns are inside the inductor), and (b) how does this actually work electronically ?
EDIT: Here's the relevant part of the schematic (from EAGLE).
The part in question looks like a transformer, and is labeled TRANSFORMER in the document. The capacitors are on the "high-voltage" side of the circuit, and the "V+" and transistor on the left are on the "low-voltage" side of the circuit.
Can anyone help me ? I am very puzzled about this question. I do need your help.
thanks in advance
