Previous in Forum: Atom Interferometers   Next in Forum: Subway-style Map for Roman Roads
WiFi Control for Evaporative Cooler
06/12/2017 9:41 AM
I was contacted on Friday afternoon by a gentleman that owns a self serve laundromat in Banning, Ca. He has two roof mounted evaporative coolers. He would like to have the coolers controlled by a WiFi capable system.
His idea was to have the coolers turn on or off by means of his cell phone contacting the WiFi controller.
I had been toying with this idea for a couple of years now, although I have not put together a prototype system, mainly due to a communicated lack of interest from the general public.
My idea was this: A wifi enabled thermostat connected to a fan control relay, then connected to the coolers fan motor. I am looking at a 2016 copy of United Refrigeration' catalog, on page 1030-1031, it shows two devices: Hawkeye 735 series sensor relay & Honeywell R8239A 1052 SPDT / R8239B 1076 DPDT.
Coolers have both a fan and a pump, so both need to operate at the same time and the fan needs to operate independently​ of the pump when necessary.
Has anyone worked on such a setup or can tell me if a component has been left out ( Circuit breaker, time delay relay, switching relay, contactor ) ?
Thanks/ Tony
Re: WiFi Control for Evaporative Cooler
06/12/2017 10:06 AM
Does it have to be Wifi? What is the advantage? Why not use a standard thermostat?
06/12/2017 10:15 AM
I have a Honeywell th6000 series t-stat that is controlled by wifi and addressable by my iphone....that would be a plug and play...
06/13/2017 4:38 AM
Bayweb.com
06/13/2017 5:44 AM
That seems somewhat abstruse. To be effective, the equipment has to respond to local conditions, not to remote on/off commands! The concept is a solution to a problem that doesn't exist.
06/14/2017 7:54 AM
...called "what else can I do with my phone that doesn't involve making phone calls?"
United States - US - Statue of Liberty - How's it going?
06/13/2017 9:38 AM
https://community.smartthings.com
https://forums.homeseer.com/showthread.php?t=137142
z wave system is your answer.
Plenty of help on these forums.
Norm
If you can't explain it simply, you don't understand it well enough. AE
06/13/2017 11:20 AM
But why do you need this? An on/off switch works pretty well. Last thing I want is an run-away evaporative cooler dumping water down the overflow inside my business/domicile. Okay, on a VCC air conditioner I can see using a remote (if nobody is home during the day), but we also need our birds to stay cool or they molt.
Register to Reply 7 comments
Gmar (1); James Stewart (2); nvirciglio (1); PWSlack (2); SolarEagle (1)
