Previous in Forum: Protect Relay Micom P243 Cannot Start Up   Next in Forum: High System Voltage Curtailing Power Evacuation From Mini Hydro Plant
Mounting Arrangement IM For Motor
06/14/2017 4:36 AM
Dear all
good day
We have low voltage motor (IM B35).but this motor is mounted perpendicular in the
site.
please what is the effect of changed the mounting form on the motor.because there
is many type of (IM) like (V15,V17,V36,B5,B5) etc.in other words are there any
effect if we installed motor type (IM V15) horizontally.
thanks for all
Pathfinder Tags: mounting arrangement
Re: mounting arrangement IM for motor
06/14/2017 5:23 AM
According to this document
www.naewoielec.co.kr/pdf/leroy_01position.pdf
The "Bs" should be mounted horizontally and the "Vs" should be mounted vertically.
But I don't know if that's just because of the mounting hardware?
The only reason I can think of that may dictate the orientation is the lubrication arrangement.
A google search for "induction motor mounting" gives loads of results. You can add "IM V15" for example to the search.
Good Answers: 116
06/14/2017 5:29 AM
Best to ask the motor maker. Problem is ... no-one else knows bearing types & loadings or whether bearing cage is held in place by rotor weight etc. Horizontal rotor may hunt back-forth & damage bearing.
06/14/2017 6:14 AM
This motor type has been designed for horizontal mount only....there's a reason for that...since they also make a vertical mount type motor it's a safe bet that you can expect premature failure if you ignore the instructions....
Re: Mounting Arrangement IM For Motor
06/14/2017 12:10 PM
What orientation is the site? Is the site vertical and the IM B35 mounted horizontal, or is the site horizontal, and the motor mounted vertical?
I would say, put it back like it was, originally, and wait for further instructions from the OEM.
06/17/2017 6:52 AM
Dear sir
good day
thanks
06/19/2017 9:29 AM
That is re-assuring, because I was worried about personnel slipping down the vertical floor, LOL.
I think if you want the motor horizontal, you will need a 90 degree gear box, else you might have to turn the world on its head.
Register to Reply 6 comments
67model (1); James Stewart (2); kasrop (1); Randall (1); SolarEagle (1)
