Previous in Forum: hybrid for two wheeler   Next in Forum: Atmospheric Heating calculation
10 comments
feed water temperature to Non IBR boiler
08/25/2007 10:32 AM
In non IBR boilers, in india, manufacturer recommends feed water temperature should not exceed 40 deg.C. why is it so? Can we use the condensate of temperature 50 deg.C to 80 deg.C to feed boiler. If yes, how?
Good Answers: 19
Re: feed water temperature to Non IBR boiler
08/26/2007 12:14 AM
Prior commenting, I might be asking a stupid question but here it goes - " Whats a "non IBR boiler"? What abbv. is "IBR"?
08/26/2007 7:20 AM
Dear ducon
IBR is the abbr for" Indian Boiler Regulation".It may be that Non IBR stands for a Low pressure boiler.Mr Shridhar has clarify the rating of boiler i.e.TPH,Kg/cm2 etc.to get the solution.
Good Answers: 19
08/26/2007 8:59 AM
Thanks. He has yet to state capacity kg/hr or Tph & operating pressure.
Good Answers: 19
08/26/2007 9:03 AM
Thanks the guest who informed me IBR.
Such Boilers I believe will be steam generators upto 600 kg/hr?
Please state if this is a Steam Generator? Is it for hot water or steam? If steam please state operating pressure Bar & steam generation.
08/27/2007 11:27 AM
This is steam generator, packaged boiler or double skinned water tube boiler; having of 600kg/Hr capacity operating at 10kg/cm2 pressure. This has economiser, air blower with burner. Fuel used is HSD and feed water is soft water...
08/28/2007 6:55 AM
Surely a telephone call to the boiler manufacturer for technical assistance would sort this one out?
08/29/2007 1:48 AM
it is because of the limitation of feed pump. normally positive displacement type feed pumps are used in non ibr boilers. if feed water temp is more, then there will be chances of vapour locking and water will not be pumped to boiler leading to watertube coil overheating and accident.
08/29/2007 3:04 AM
I am thankful for your inputs.... i am in touch with the manufacturer M/s.Thermax. As per them, it is not recommended. However i am seeing feasibility / opportunity to use condensate water (without using heat exchanger) to feed the non IBR boilers...
Good Answers: 19
08/29/2007 7:25 AM
i agree with Radtherm.
If you change your pump to give feed water at 100C then you will save 1% fuel or increase boiler efficiency 1% with every 6C rise in your feed water temperature.
Your savings can be upto 11%. The difference in the cost of replacing the pump will be paid off within 6 months plus the increase in the boiler/tube life with minimized thermal shocks with feed water at 100C rather than at what temperature you are presently giving it. Consult your Boiler Manufacturer.
IBR VALVES & NON IBR VALVES
03/26/2009 5:45 AM
MAHAVIR METAL INDUSTRIES
S I N C E - 1 9 6 9
Mfrs. of : G.M., Bronze,S.S., C.I., F.S., C.S. Boiler Mounting & Steam Valves
B-172/B, Industrial Area, Jalandhar-4 (Pb.) INDIA
Ph. : O. 0181-2290331, 5008511 R. 6539511
Contact Person: Sumit Jain
9216008511
Subject: Enlistment As Approved Suppliers
Dear Sir,
It is humble privilege to introduce ourselves as one of the leading manufacturers of Bronze, Cast Iron and Cast Steel Valves, Cocks and Boiler Mountings for general purposes and steam lines service in the brand name 'MAHAVIR' since 1969. Our products are known for their excellence in design, finish, workmanship and performance. Our company flourishers in the demanding business of valve manufacturing due to our quality par excellence, our dedicated workforce, our commitment to quality and customer service and proven record of reliable on time deliveries.
MAHAVIR Brand has earned the goodwill of superior performance and reliability for all its products over the last 39 years in the national as well as international market.
The range of our products covers Bronze Gate Valves, Globe Valves, Horizontal Check Valves, Vertical Check Valves, Ball Valves, Union Bonnet Globe Valves, Union Cover Check Valves, Foot Valves, Main Cocks Gland Cocks, 'Y' Type Stainers, Safety Relief Valves and IBR Certified Bronze, Cast Iron, Cast Steel Valves and Boiler Mountings etc.
You are requested to kindly enlist our name in your approved supplier's list for the supply of 'MAHAVIR' Brand Valves, Cocks and Boiler Mountings and send us your valued equerries/orders as and when required.
Your favorable action in the matter shall be highly appreciated.
Thanking you and assuring you our best services always.
Register to Reply 10 comments
Anonymous Poster (2); ducon (4); PWSlack (1); radtherm (1); shridhar (2)
