I have fuel injector pipes to be insulated on a V12 air-cooled diesel engine. The fuel pipes is ±6.5 mm outside diameter and 1150 mm lg. It runs over
an exhaust pipe that is ±700°C inside (measured gas temperatures), but the hot air blown over the fuel and exhaust pipes are ±110-180°C (measured), thus I want to insulate the fuel pipes from the injection pump to the injectors. The pipe material is Stainless Steel (grade unknown). There is some degree of flex or movement inside a fuel injection pipe and the fuel temperature inside the fuel pipe will be less than 100°C (estimate). Please let me know if you have an solution /answer for my problem?
