Previous in Forum: What is Intel Optane?   Next in Forum: Hearing Damage in U.S. Diplomats in Cuba
16 comments
Good Answers: 137
Thread Query
09/15/2017 4:01 AM
Does anybody remember a query posted 1 - 2 years ago (if memory serves) about air flow through a pipe connected to an air receiver, discharging to atmosphere?
I've searched the forum using every keyword I can think of without success. Somebody, James Stewart I think, posted a link to a calculation. I've tried the internet but can't find anything suitable.
Appreciate any help.
Re: Thread query
09/15/2017 4:49 AM
In case you haven't tried this:-
https://www.google.co.uk/search?q=site%3Ahttp%3A%2F%2Fcr4.globalspec.com+air+flow+pipe+receiver+atmospheric&oq=site%3Ahttp%3A%2F%2Fcr4.globalspec.com+air+flow+pipe+receiver+atmospheric&gs_l=psy-ab.3...108837.146875.0.153409.45.45.0.0.0.0.85.2666.34.34.0....0...1.1.64.psy-ab..11.0.0.3Gzx_FP2ozc
Basically you do a site specific search in google using a string like this:-
site:http://cr4.globalspec.com air flow pipe receiver atmospheric
It's just that google is better than CR4's own search engine. But don't include the CR4 names of people you thought responded unless you're sure their names were mentioned in one of the relevant posts: I think those user names fall into a "different space" as far as google is concerned.
Re: Thread Query
09/15/2017 11:54 AM
wow, I can't remember either, feature that. Searching...
this one
rapid air one
Parker one
ETB one
could it be one of these?
Good Answers: 137
Re: Thread Query
09/15/2017 2:51 PM
Thanks for that. Sounds like it wasn't you who posted the link on the earlier thread.
The first 3 links here give pressure drop when flow and pipe size, giving a selected, moderate velocity are known.
ETB one has a section
Air Discharge through Hose - Discharging air volume through hoses at pressures ranging 30 - 90 psi
which is more like what I'm after. Results of my calcs aren't vastly different, which is reassuring. I'd ideally like to be able to enter up and downstream pressures, length and dia and get flow, but this link is the best I've got so far!
Re: Thread Query
09/15/2017 4:10 PM
Good. Let us know how well things match up, if you get good data?
Good Answers: 137
Re: Thread Query
09/19/2017 1:13 PM
Had a few more thoughts. Looking at the isothermal case, the equation is
which can be solved directly for mass flowrate m, when p1 and p2 known, the case I’m interested in. p2 atmospheric pressure, 1 bara.
My book says the exit velocity from the pipe cannot exceed Mach No. 1/g = 0.845. I’m looking at a case where using calculated m, and pressure hence gas density at p2, Mach No. comes to 1.2. The book doesn’t say what to do about that. I could recalculate (by trial) m to give Mach 0.845 at that density, but I think that underestimates the flow. In an orifice at supercritical pressure drop, there’s sonic velocity in the orifice, but the density is something like upstream density, for mass flow calculation. A bit more complicated than that, but it definitely isn’t downstream density or the mass flow would be independent of upstream pressure, whereas it varies directly as u/s pressure.
So I’ve assumed the effective downstream pressure is higher than p2, and using Mathcad calculated the effective downstream pressure, density and mass flow (which are of course related) to give Mach 0.845.
Still looking at the adiabatic case, but the book says they don’t in practice differ all that much.
I don’t know what you think (if you have an opinion about it ).
I’d have liked to find the online calc I was referring to, for a check, but I’ve tried every keyword I can think of without success, beginning to wonder if I imagined it!
Re: Thread Query
09/19/2017 1:33 PM
How about searching directly for subsonic and supersonic nozzles?
NASA mass flow choking
This one indicates maximum flow at Mach 1.
Compressible mass flow at a nozzle at Mach 1
And this for isentropic flow at converging or diverging nozzles (can be supersonic on divergent nozzle)
isentropic nozzle flow
Good Answers: 137
Re: Thread Query
09/19/2017 3:18 PM
Just found this! http://cr4.globalspec.com/thread/112378. So it was you!
It's the thread I thought I remembered, but a lot more recent than I guessed. Haven't had time yet to check if it gives me what I'm after, but it looks promising..
Good Answers: 137
Re: Thread Query
09/19/2017 2:24 PM
Minor point - should have said cannot ".........exceed Mach No. 1/√γ (gamma) = 0.845."
Re: Thread Query
09/19/2017 3:45 PM
If I recall, this γ is the compressibility of the air....correct?
Good Answers: 137
Re: Thread Query
09/20/2017 4:25 AM
No, γ is Cp/Cv, specific heats at constant pressure and volume, 1.4 for air. There's expansion factor Y in orifice and nozzle calcs. Not easy to tell the difference in CR4!
Re: Thread Query
09/15/2017 12:19 PM
Good Answers: 137
Re: Thread Query
09/15/2017 2:25 PM
Thanks, but orifice or nozzle flow isn't quite the same. That's reasonably straightforward when you've got your head round it. Discharge through a longish pipe is more complicated. I'm looking at a fluid mechanics book but it isn't easy to follow. I think I've got the isothermal case sussed but in practice it's more likely to approach adiabatic, as the velocity will be high.
Unless my memory's gone to pot, the link I referred to allowed you to put in up and downstream pressures and it gave the flow. I hoped to use it to check my calculations.
Re: Thread Query
09/15/2017 4:04 PM
Good Answers: 137
Re: Thread Query
09/19/2017 1:05 PM
Thanks for the link, unfortunately the calculator won't run on my old 32-bit computer. Also they wanted paying for it, which I wasn't planning to do as it's only for my interest. But it doesn't look expensive, so I might go for it when I upgrade the computer.
I found this link Flow of Gas from Tank through Pipe which might interest. They also charge for it (rather more than yours) and it doesn't give much confidence when it says the Reynolds No. is constant in adiabatic flow, as falling temperature decreases gas viscosity hence increases Reynolds No.
Re: Thread Query
09/15/2017 12:31 PM
My next question: did you post on someone else's thread, or were you the OP?
Good Answers: 137
Re: Thread Query
09/15/2017 2:08 PM
I wasn't the OP. (I think even I would be able to trace it if I was !) I don't think I posted on the thread, as I couldn't add anything to others' comments, but I read it with interest.
Thanks anyway, I'll reply to other posts shortly.
Register to Reply 16 comments
Codemaster (8); James Stewart (5); Randall (1); SolarEagle (2)
