Previous in Forum: Hydraulic vehicle drive   Next in Forum: CFM Calculation for a Fan?
Aero calc: airstream on a cylinder
08/28/2007 5:34 PM
Need help calculating the force of an airstream acting on a cylinder segment. Also, the cylinder axis is tilted into the airstream at an angle of attack (picture an aircraft door on the belly of a circular aircraft fuselage).
Thanks for any references.
Re: Aero calc: airstream on a cylinder
08/29/2007 3:38 AM
The 'drag coefficient' relates the instantaneous force on the cylinder segment to the velocity of the stagnant streamline. Needless to say, the drag coefficient varies with airspeed. Check out a good aeronautical engineering textbook. Perry's 'Chemical Engineers' Handbook' also gives several methods of determining this.
08/29/2007 12:04 PM
Thanks for the reference, I'll take a look. The aero books that I have looked at treat flow around a cylinder that is normal to flow direction. The angled cylinder axis is putting a twist on the problem.
I have heard suggestions to use projected cylinder area normal to flow but I hope to find a published example, or a more developed suggestion.
Register to Reply 2 comments
