I am interested in diffusing gas (carbon dioxide) into water. An existing system has large holes in pipes and the CO2 bubbles out of the tank before reaching saturation. I know it is not near saturation because I am watching the pH. As you can imagine the ratio of surface area to volume increases geometrically with smaller bubbles, and performance better.
I am trying to size a sparger. To do this I want to estimate surface area and volume of gas bubbles using a sintered metal sparger. Pore openings are available less than 3 microns and there is more than 50 psig available to put CO2 into an atmospheric water tank. I recall seeing films and photos of similar systems that either make many small bubbles (good) and with too much pressure the conditions let it regroup to one large bubble (bad).
The question is: Does anyone here have experience or references with a CO2 / water injection system that has measured mean bubble diameters from injection systems?
I have checked with supplier websites, CO2 suppliers and continue to wait for a reply.
