Previous in Forum: Regarding Cable Size As Per Motor Details   Next in Forum: Quantum Computing and Predicting Material Properties
13 comments
Cable Size and Gland Size
10/05/2017 2:02 AM
Sir
Pls August the following motors cable size with gland packing details.
Pulper-350kw
2)Turbo 1000- (132kw)
3)pulper-200kw
4)vaccum pump-action -110kw
5)couch roll-250kw these all require for paper machine.
Kindly August me cable size as well as cable gland size also
Thanks
D. Chinna kumar
D Chinna Kumar Late D George
Good Answers: 1693
Re: Cable size and gland size
10/05/2017 3:05 AM
Good Answers: 53
10/05/2017 2:32 PM
Don't go by First name.
He seams to be my fellow countryman. Clues-
Second name, And Full name at Bottom, Its not spell error
10/05/2017 3:14 PM
Essentially, the same answer with our friend in India, not China. We cannot help unless given better details. We have no idea what his distributed voltage, phases are.
10/05/2017 7:04 PM
I think you'll find he's in Kenya: which is why my search was done in google kenya.
10/05/2017 5:24 AM
Re: Cable Size and Gland Size
10/05/2017 6:21 AM
British Standard 7671.
10/05/2017 6:35 AM
August is the proper name for a month in several languages.
It isn't a verb in the English language.
Do you mean "advise" instead?
10/05/2017 6:56 AM
I think it is obvious that he / she meant to say "Suggest".
But I guess correcting someone's grammar, that obviously does not speak English, is easy when done behind the banner of anonymity.
Anonymous Poster #2
10/18/2017 11:14 AM
Wait, what are you doing calling AP#1 out for being a jerk?
That's supposed to be MY job.
10/18/2017 2:42 PM
I thought it was coming to the party late and posting 4 months after everyone had moved on?
<tongue firmly in cheek>
Anonymous Poster #2
10/18/2017 3:48 PM
I'm supposed to pick on AP#1.
I SHOULD be timely about it.
I never said I was GOOD at my job.
10/05/2017 12:31 PM
We cannot August right now, it is October.
Did you mean adjust? Or did you estimate the correct size? Oh, I see you meant "suggest".
Good luck. For that range of power you need 000 cable. 4 gauge will not do.
Hint: It really depends on the current draw expected, and the higher voltage equipment does not require as much current.
If you want to run on 12 VDC, you need giant cable.
10/05/2017 3:06 PM
Get someone qualified to specify and install these, they are not something a purchasing department (or similar unqualified individual) should be attempting to specify themselves.
Answers on our part would only be guesswork and without knowing the exact application all we could do is guess as there is no single right answer due to all the numerous different things that could effect the selection.
Register to Reply 13 comments
Anonymous Poster (3); jack of all trades (2); James Stewart (2); JPool (1); lyn (1); PWSlack (1); rakesh_semwal (1); Randall (2)
