Previous in Forum: Wavelength and Frequency of Absorbent Materials   Next in Forum: DAS
12 comments
Lord Hero and Leader
08/30/2007 1:35 AM
I am looking for information on a communicaton system that references to Lord Hero and Leader.
As in the water face reflects face,so the Heart of man reflects man. Proverbs 27.19
Friend of CR4
Re: Lord Hero and Leader
08/30/2007 9:09 AM
I'm not sure what you're looking for. Can you clarify what you mean by Lord Hero and Leader?
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
08/31/2007 2:20 AM
Chris. Hello. I am in the midst of a stalking situation. I have gone through just about every electrical item in my home . Researching wiring , cables, modules etc. and I am constantly brought back to a RF military Coast Guard system. I have found lots of ceramics, nanos etc. I am actually living in the midst of a nightmare. I went along way around to get to the Lord Hero and Leader..a couple of the wires that are typed as networking GPS wires have on them Leader and Lord hero, another word on a ceramic led Lung Hui. I am trying to figure out exactly what has been put in here.
What do you think does any of this sound familar to you?
Thanks for your help.
Jackie
Friend of CR4
08/31/2007 8:39 AM
It's nothing I've ever heard of before.
08/31/2007 2:16 PM
Chris . If you happen upon any info.that might give me insight into this PLEASE let me know. Thanks Jackie
Good Answers: 97
08/31/2007 9:01 AM
The Lord Hero & Leader may actually mean base or earth and positive.
May be due to translation from and back to English via another.
It wires may be intended to go to the aerial, transformer, power transistor or line input.
Maybe you are Lucky because the thing may be out of order.
08/31/2007 2:13 PM
Hendrik. Thanks for your feedback, I believe transformer is probably the key. If you come of with anything else. PLEASE let me know. Thanks Jackie
09/01/2007 2:54 PM
Hendrik. My situation is so strange but i will do my best to simplify it. My x-husband is the one whom installed this system. He is a former Federal agent who worked covert most of his life and still has access to this type of equiptment.The story is so long and complicated I find it hard to relay it in a short post, so I will use bullets as my form.
1.Wiring and cable in my home was rearranged,or a new type installed. incaps on the cables checked out to be video streaming or RF signal.
2. Wiring on electrical appliances tampered with discovered GPS & Network wiring added.
3. Audio amplification (little black boxes)Sorry for the discription a tech person I am not. put on my ceiling fans as well as the sockets on the fans had been replaced with
09/01/2007 3:11 PM
Continuation. bulb sockets on fans had been changed to ceramic with names on the Lung Hui etc. and the bulbs had been replaced with bulbs such as ABCC and sec and satoo that come back to photo or audio enhancing.
Wiring in exterior light fixtures have wiring that are marked Lord Hero, Leader, etc.and the light fixtures have been painted with a dark,flat in finish ....what I believe to be some sort of Nano, liquid crystal, or something to enhance RF signal.
I know my phones and my cell phone have been monitored by this system.
The wiriing and modules on my TV's have been minipulated.
A lot of the styles, types, numbers, modules etc, come back to military grade and I do know that it can be monitored by Air.
I pick up strong RF in the areas of my walls that the wiring was manipulated. I can also hear poppping in my walls when this is activated.
09/02/2007 4:06 PM
hello.
you got a fancy problem I guess.
I am not a specialist on this matters but, I´ve never heard notting like that before!
perhaps those codes were given by the sistem engineer to mark the aparatus,as like in a signature , or some kind of code similar to the ones used in the armed forces (e.g: alfa, bravo, tango, etc...)
and maibe , it could be a false lead to confuse persons .
have a nice day!
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
09/02/2007 11:54 PM
I have way too much physical evidence for it to be false leads. But thanks for your reply.
09/03/2007 3:10 AM
Hello Jackie.
If thats the case you should take measures to protect yourself.
there´s little more to say.
good luck
Good Answers: 97
09/03/2007 2:35 AM
Way over my head and I suppose it would be hard to understand even for a reverse engineering electronic expert. Some of the contraptions will be smoke screens or may be deliberately labeled incorrectly.
I don't know much about US law but would suppose that the right of not having ones privacy and privacy of ones communications infringed is high on the list. A warrant would be required to install a tap.
I would talk to the state or consult an attorney and charge the state for illegally violating your rights. They have to produce a valid warrant or undo the harm.
I know it might not be the state that installed it but the state should be responsible for the doings of any employees.
Best of luck.
Register to Reply 12 comments
Chris Leonard (2); electronick (2); Hendrik (2); jackie (6)
