Hi friends, there was two instances at my office where in we lost some PC's modems & fax machines due to surge voltage which were all fed with UPS supply (1 no. 80 KVA UPS). As in the case clearly specifies that UPS had failed to cut-off the surge voltage, what could be the reason for the surge. If it is in the from the main source, all the offices in our complex should have got affected. But that was not the case. Is there any possiblity of surge voltage from ups due to malfunctioning. Is there any protecting device availabel for the same?? pls. help me out...
