Previous in Forum: bolt torque   Next in Forum: energy storage
power rating
09/01/2007 1:02 PM
hi
may i know what is the formula to calculate power rating of a dc motor?
a learner..
Good Answers: 143
Re: power rating
09/01/2007 3:18 PM
Do you mean how much power does it consume or how much does it provide? What kind of DC motor? Give some specifics, please.
Re: power rating
09/01/2007 11:19 PM
actually im planning to build a clothes horse that can cover(like a rain protector) the clothes when its raining.Then i need to use a motor to move the cover(example canvas)around the reel of the clothes horse.Btw the clothes horse shaped like a tall cylinder.I dont know what type of motor to be used and how much power rating of the motor.Because the clothes horse is going to be placed outside the house, i prefer to use a solar panel as a power supply.But the problem is that i dont know how to find the right solar panel and also the motor.
Given: Diameter of the railing, D =1.3m,
Parameter of the railing, P= pi x 1.3m=4.084 m,
Diameter of the gear attached on motor, d = 0.02m,
Distance travel for 1 rev of motor = pi x 0.02m = 0.06283m
Since the canvas cover must covered the railing under 5 seconds. It means 1 second the canvas cover must travel =(4.084m/5)=0.8168m
The speed of motor needed to turn in order to closed the canvas cover under 5 seconds,
Revolution per second = 0.8168/0.06283 = 13
RPM = 13 x 60 = 780
Torque, T = Fr
=14.7 x 0.01m
=0.147 Nm
Power of the motor, P = Tw
=0.147x780x(2pi/60)
=0.147 W
if im not mistaken the formula found in the internet for hp= (5252xrpm)/T
thus by doing so, the power rating of the motor is = 16.6W.. is it correct?
and one more questions, can i use a 12V solar panel with 0.2Amp(the power rating = 2.4W) to supply the power for the motor?or do i need a larger value of power to the motor?
a learner..
Re: power rating
09/02/2007 12:01 AM
Don't you have AC 3 hase around?
DON'T YOU have a small 3Phase1/4> 1/2HP motor readily available?
Rig up one with reversing pair of contactors+limit switches operating with your sensor/controls.
Do not waste your time going to squeeze a WAtt here ,a Watt there--even if your actual load is miniscule.
Register to Reply 3 comments
MUKULMAHANT (1); TVP45 (1); zahirah86 (1)
