Actually this is related to mechanical as well electrical engg, so I preferred to put it in general section.
We are taking trials on Induction brazing m/c, as we are into replacing of flame brazing by Induction brazing. Induction brazing has several advantages over flame brazing. But, there is one problem. The magnetic field of high frequency Inductor used for heating the brazed joint, causes the smaller silver buttons (which are brazed to bigger Copper job) to move or rotate as sson as filler metal melts.
I can't hold the Silver button in place, as we are sliding the button while brazing to increase wettability & expel any gases that may trap within the joint. The sliding has to be done without applying much pressure, but with Induction brazing if you apply less pressure the Silver butto moves & if more pressure is applied the The joint results in more voids.
As I contacted various manufacturers, they told me that the higher the frequency the lesser will be pulling effect, so I tried with brazing at 120KHz frequency (10kW power), but still the magnetic field is sufficient to make the silver button go out of control.
So is there any Induction Brazing /heating expert who can help me?
Should I go for still higher frequency, as equipments are available with 450 KHz?
