Previous in Forum: How to Remove Deformation in End of Aluminium Pipe?   Next in Forum: Help in Identifying a Meteorite Revisited
12 comments
Wire Up 220 Volt Variac
01/19/2018 11:44 AM
Hello All,
Need some wiring assistance here,
Trying to wire up a 220 volt variac, I have done dozens of 110 volt versions, and it is simple. It;s is more or less just like a GIANT Potentiometer.
A common ground or "Neutral, and hot on the input and a common or Neutral and sliding tap on the output.
But on 220 input power, UG! ya got this coming in,,
B= Neutral or ground, and two Hots, A & C
Now what would go to where on this multi gang beast here, the manufacturer says it will do as a 220 volt variac,
But how would I wire it up so I get on the output zero to full voltage swing?
Joe
Re: Wire Up 220 Volt Variac
01/19/2018 12:39 PM
01/19/2018 12:50 PM
Yup that explains what I have always known when doing like a 110 volt one.
But the 220 is for some reason baffling me.
01/19/2018 1:06 PM
01/19/2018 1:32 PM
Ok those all deal with 110 variacs, I have done dozens of them the 220 is what was blowing me away but i thnk I got it, what ya'll think of this?
Joe
01/19/2018 1:46 PM
He says in the first video at 3:21 that the wiring is the same for 120 or 240....
01/19/2018 2:12 PM
Good Answers: 29
01/19/2018 1:47 PM
Are you using two 110 volt variacs?
01/19/2018 2:02 PM
https://www.torontosurplus.com/industrial/transformers-variable-variacs/general-radio-w20g3-genrad-variac-autotransformer-3-gang-w20-single-or-3-phase-see-description.html
01/19/2018 2:16 PM
Ask the guy for an appropriate wiring diagram....
https://www.torontosurplus.com/productquestion/index/index/product/6020/
Good Answers: 29
01/19/2018 2:43 PM
That should work, assuming the wipers are both mechanically connected and they turn in the same direction (i.e. left in the schematic is counter-clockwise and right is clockwise or vice-versa).
You'll have one unused variac out of the gang of three.
Since both inputs are hot, make sure you switch and fuse both of them.
01/19/2018 3:34 PM
Yup it worked, Yay!
02/05/2018 2:13 PM
In your picture (though very clear) I can't read the name plate data. This was a 3 phase unit and I think transformers may EACH have a primary designed for 230 volts. If that is case operating at 120 volt primary you may have less capacity than you think. Example: If each 1 kva, 240 volt you are limited to ~4 amp load at any voltage so if set for 50 volts only 0.2 kva available. If I am correct, and assuming 1kva each, you could wire differently to get 12 amp output.
Register to Reply 12 comments
hoo8975 (1); Lo_Volt (2); NSS (4); SolarEagle (5)
