Previous in Forum: Electrical Lift For 20kg Load For 30m Height   Next in Forum: Optimum Selection of One Common Spare Motor Against Three
8 comments
Good Answers: 170
Ground Fault Factor
01/27/2018 6:43 AM
What should be the Ground Fault Factor for the following systems:
i) Solidly Grounded
ii) Low Resistance Grounded
iii) High Resistance Grounded
iv) Low Reactance Grounded
v) High Reactance Grounded (Peterson Coil Grounded)
This is is connection with the Selection of rated voltage for Lightning Arrestors/Surge Arrestors.
Please do not suggest any manufacturers' brochures/catalogues. I have seen enough, but could not get a precise reply.
Re: Ground Fault Factor
01/27/2018 6:58 AM
Recently an internet search engine produced 982,000 results on this topic, among which the required electrical expertise may certainly be found.
01/27/2018 10:19 AM
ratio of the highest root-mean-square value of line-to-earth power frequency voltage on a healthy line conductor during an earth fault affecting one or more line conductors at any point on the system, ...
earth fault factor - Electropedia
Determination of the Earth Fault Factor in Power Systems ... - Icrepq.com
I usually just go with 5.
Good Answers: 42
01/28/2018 12:08 AM
Please refer IS 3043 1987 (reaffirmed 2001) . You may get answer for all your earthing problems in that . Normally I follow this IS for all my earthing requirements and that is acceped by Electrical inspectors. IEEE standard 80 2000 for safety for Substation grounding is another reference I use for my Earthing problems.
01/28/2018 5:10 AM
hello, i don't know from which country you are coming from but what i will suggest you is to look for your electrical inspector. He knows the rules and regulations of your electrical board more than us; especially in earthing.
If you are in need of some of my writing services for yours blogs or websites, feel free to reach me here:https://www.fiverr.com/patye91/write-blog-posts-news-reviews-in-electrical-engineering
01/28/2018 10:35 AM
"I have seen enough, but could not get a precise reply."
Maybe that's because there's not a precise answer to such a horrendously broad group of general questions.
These sound like test questions of interview questions, not real life situations!
Follow the local codes!
Good Answers: 445
01/30/2018 1:16 AM
You may find this paper useful, depending upon the level of analysis you wish to use.
Good Answers: 42
02/01/2018 11:12 PM
It is good paper. Thanks. This is another paper on Earth fault factor http://icrepq.com/icrepq%2710/699-Calado.pdf
Good Answers: 42
02/01/2018 11:35 PM
Sorry It is same paper.
Register to Reply 8 comments
lyn (2); patye91 (1); PWSlack (1); RAMConsult (1); V.I.Abraham (3)
