Previous in Forum: Controlling a Linear Actuator with a PLC   Next in Forum: Contactor Humming as Soon as Voltage Increases
Role of Diode
01/31/2018 9:23 PM
Hi there, I just want to know the roles of these two diodes in the circuit (DC motor control board) attached.
Please let me know some details.
Thanks!
* the image is not clear, but I guess you could answer me in general way..
5
Re: role of diode
01/31/2018 9:56 PM
It is hard to tell from your fuzzy diagram but my WAG is that these are flyback diodes. A flyback diode provides a safe current path for when an inductive load, motor winding, gets turned OFF. Without a planned flyback path the inductor will create enough voltage to make a current path.
Re: role of diode
01/31/2018 10:14 PM
Re: role of diode
03/08/2018 2:21 PM
What a simple trick. Just flip the video and now all of the backwards writing is forwards. Maybe they got even simpler and just used a mirror. The only give away is the buttons on his shirt.
Re: role of diode
01/31/2018 10:45 PM
Re: Role of Diode
02/02/2018 6:08 AM
Good question!
"On the L293, external high-speed output clamp diodes should be used for inductive transient suppression. On the L293D, these diodes are integrated to reduce system complexity and overall system size."
Re: Role of Diode
11/29/2022 2:49 AM
They stop high voltage transients getting back up the supply rails and hurting other semiconductors. And people who might be in contact with them.
Register to Reply 6 comments
PWSlack (1); Randall (1); redfred (2); SolarEagle (2)
