Previous in Forum: Bypass Isolator   Next in Forum: High Voltage in Generators
Starters
02/08/2018 11:59 PM
What are starters in 3 phase induction motors to limit the speed
Re: starters
02/09/2018 12:22 AM
You mean a Variable Frequency Drive (VFD)....?
https://en.wikipedia.org/wiki/Variable-frequency_drive
Re: starters
02/09/2018 1:18 AM
Or maybe a Star-Delta start?
Building the future!
Re: starters
02/09/2018 3:53 AM
The speed in an induction motor with direct-on-line starting is governed by the frequency of the supply.
Good Answers: 804
Re: starters
02/09/2018 11:16 AM
... and the number of poles in the motor construction.
Re: Starters
02/25/2018 11:34 PM
Starter is a technical names given to a device that is used to start any induction motor from its initial speed up to the maximum speed. Devices like Direct On Line Starters (DOL) or Star Delta Starters (that start a induction motor from star point to Delta point at full speed).
Ivanov327950 (1); JRaef (1); PWSlack (1); Simon Wan (1); SolarEagle (1)
