Previous in Forum: Can you save money by installing solar panels (PV) on your house?   Next in Forum: Global Dimming
Steam and coal cost for DEc Tg set
09/10/2007 1:59 AM
I would like to know the steam & power cost from a typical double extraction cum condensing turbine where the feed to the TG would be at 64 kg/cm2,"g", 460deg.C with a flow of 225 tph ,extraction at 11 kg/cm2 "g" 260 deg.C with a flow of 35 tph and at 4.5 kg/cm2 "g",190 deg.C with a flow of 160 tph .Condensing would be at 0.1 ata, 45 deg.C.with a flow of 30 tph.The steam from waste heat boiler is 155 tph and from coal fired boiler is 75 tph.Coal cost is around Rs.1500/ton of coal (=36.5USD)
Re: Steam and coal cost for DEc Tg set
09/10/2007 7:58 AM
Well, there's probably enough numerical information here for an Engineer to work it out for herself.
09/11/2007 11:50 AM
<herself.>
Its a HE.
09/12/2007 2:34 AM
I did not get a correct reply.
09/11/2007 10:14 AM
You need another tutorial. It's so much more rewarding when obtaining your degree having done it all yourself...!
Register to Reply 4 comments
Anonymous Poster (1); MUKULMAHANT (1); PWSlack (1); vasu (1)
