Previous in Forum: Earth's Magnetic Pole Drifting More Quickly Than Believed   Next in Forum: Honda to Manufacture Solar Cells
240V single phase to 415V three phase converter
12/09/2005 2:33 PM
Ronald Cassar writes:
I want to build a 240V single phase to 415V three phase converter but I don't have a circuit diagram. Can someone help me to find one?
12/10/2005 12:03 AM
There is a guy on eBay that sells plans he will email you for about $5 that use 3 phase motors. You will still need a step up transformer. This is not the best 3 phase and it involves running the extra motor. Probably the best and simplest way to go is find yourself a single phase 240 to 480 transformer then go on eBay and there is a guy selling new Toshiba solid state single to three phase converters starting around $200 with more features than you can shak a stick at. Good luck!
Re:three phase converter
12/14/2005 4:00 AM
Yes, it is a good idea but I want a circuit diagram of a single phase to three phase converter so I can build it by my self because I have a proget to do
01/08/2006 11:29 PM
Try this excellent explaination: http://home.att.net/~waterfront-woods/Articles/pha seconverter.htm
Re: three phase converter
06/06/2010 11:40 PM
Hi there,
Would a single phase 230-240 transformer do the trick?
Re: 240V single phase to 415V three phase converter
02/05/2009 12:43 PM
Hello all, I think I might be acquiring a 3 phase 480v plasma cutter, (circuitry damaged but I should be able to repair) so company might be tossing out for new one. So this leaves me to getting 3 phase in my home garage, I have settled on making my own Rotary converter and am only looking to power the Plasma cutter. The cutter draws 27A @ 480VAC 3 phase, what size motor would I need for the inverter or could someone guide me towards the proper equation for motor size and Capacitor selection Thank You
We cannot solve today's problems with the same level of thinking the created them---Albert Einstein
Anonymous Poster (2); JCD_Sparks (1); rcapper (1); satuser083 (1)
