Previous in Forum: Bus and Switching Definitions   Next in Forum: Building a Shunt From Nichrome Wire, W-3205
8 comments
The Return Path Of A Third Rail
09/11/2007 3:21 PM
third rail has only 1 conductor..what is the return path of it???
Good Answers: 52
Re: the return path of a third rail
09/11/2007 3:25 PM
Ground, that is the other two rails
Re: The Return Path Of A Third Rail
09/12/2007 5:48 AM
Some background reading on the Hong Kong Mass Transit railway would be of interest as to the sort of things that can happen when the return ground/earth path is inadequately bonded. On a DC supply, the return currents were passing through parts of the re-bar in the concrete support structures, causing accelerated corrosion effects in it leading to structural deterioration. Google it!
09/12/2007 9:20 AM
Isn't it always the "little" details that bite us in the rear?
09/18/2007 7:56 AM
Just this past weekend, I read an article about outside rail powered trains that had another rail down the middle of the running rails. This was used for return to ground as there was some problem using the running rails. It looked like Lionel track with a fourth rail on the outside.
Eschew obfuscation.
09/12/2007 10:40 AM
"third rail has only 1 conductor..what is the return path of it???"
From 3rd rail, 3rd rail pickup shoes, traction motors, train wheels, to the two ground rails.
09/12/2007 3:36 PM
thank u all...i got my ans......its two other rails....i guesed that but 2 b comfd just asked in cr4
Good Answers: 101
09/13/2007 4:16 AM
The running rails.
09/26/2007 7:04 AM
Yes, Ground.
BNDas
Register to Reply 8 comments
biswanath.das (1); Brave Sir Robin (1); DVader1000 (1); frankd20 (1); Kyoto (1); PWSlack (1); Stirling Stan (1); tanusree (1)
