Previous in Forum: Maximum Time Interval Between Commissioning Tests and Energization of Equipment   Next in Forum: Allen Bradley
8 comments
ELR Tripping Sometimes While Starting the Motor Through VFD
04/08/2018 7:31 AM
Hello,
I have recently changed a VFD in my company and after installing the new one (15KW), while switching ON the motor , the earth leakage relay trips ( sometimes). Is it due to leakage current from vfd? I changed the default carrier frequency of vfd from 8Khz to 6 Khz, and then afterwards ,the same ELR started tripping while turning on other motors with other VFDs.
Good Answers: 445
Re: ELR Tripping Sometimes While Starting the Motor Through VFD
04/08/2018 12:07 PM
Why was the new VFD installed? If the problems occurred after the new VFD was installed, then contact the VFD manufacturer. If there were problems that led to the replacement of the VFD, then make sure that the problems were resolved properly.
Good Answers: 804
04/08/2018 4:52 PM
Newer VFDs use transistors that turn on faster than old ones, upward of 10x as fast. So that then increases the common mode noise that is created by the drive and that often shows up as causing nuisance trips of ground / earth fault protective devices. Add a shielded isolation transformer ahead of the drive, add common mode chokes (ferrite cores) to the output conductors, make sure everything is properly grounded, turn your carrier frequency down to 2kHZ.
04/08/2018 5:05 PM
This hardly sounds like a step forward if you have to do all that just to make it work properly.....even if it is cheaper...
Good Answers: 804
04/09/2018 3:15 PM
Very few drives need to be installed behind Earth Leakage / Ground Fault protective devices that would be sensitive enough to trip on the CM noise involved here. it's a rare enough situation that it's dealt with on a case by case basis. I only brought it up by way of an explanation because the OP had CHANGED from an older drive to a newer one and had not previously experienced it.
Good Answers: 445
04/08/2018 6:02 PM
Another thing to check is if all the motors are rated for "Inverter Duty". Many older motors are not, and the fast rise times from VFDs have a nasty habit of slowly puncturing the end-turn insulation in them. Many times this incipient failure mode exhibits itself as higher and higher earth leakage current.
04/09/2018 11:02 AM
I would highly recommend installing a Line Reactor ahead of the VFD.
Dave Oliver
04/09/2018 5:06 PM
  • Question the need for the earth leakage relay.
  • Question its setting.
  • Question the quality of the VFD. If it is new and CE-marked, for example, then this sort of thing shouldn't happen.
  • Question what happens when the VFD is removed from circuit and the motor is started by other means.
  • Evaluate what to do after the above has been completed.
05/08/2018 2:59 AM
Some VFDs equipped with EMC/RFI filters to protect them from the radio frequency which causes capacitive current discharge to ground during power up where using ELR or ELCB is not sufficient, so check with manifacturer.
Register to Reply 8 comments
daveoliver (1); Fardan (1); JRaef (2); PWSlack (1); RAMConsult (2); SolarEagle (1)
